Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 11-20-2005, 08:05 PM
Jayhawker Jayhawker is offline
1989 1.5 won't fire
Just finished installing a 1.5 from an 89 HF into my 88 HF. THe engine cranks but we can't get it to fire. There is spark at the spark plugs. The CRX sat for at least 1 1/2 years before we tried to start it today. There is still fuel in the tank, could that be the problem with the gas being so old? If so, I would guess that the fuel lines need to be blown out and the fuel filter changed...any other ideas?
WTB: 88-91 CRX Si
WTB: 88-95 Civic Hatch
Old 11-20-2005, 08:27 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
Re: 1989 1.5 won't fire
i used 2 year old gas. it should still run off that gas
Team Lonely Drivers
Old 11-20-2005, 08:40 PM
Is there a possibility that the injector(s) could be bad? If so, how do I test those? A fuel filter wouldn't hurt would it? We are almost out of ideas.
WTB: 88-91 CRX Si
Old 11-20-2005, 09:05 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
http://www.automotiveforums.com/vbul...d.php?t=484679
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 11-22-2005, 04:28 AM
CrxFreak91 CrxFreak91 is offline
the injectors rarely go bad... i hate to ask but are the spark plug wires in the right order
3 4
1 2
Old 11-22-2005, 02:52 PM
Yes, I couldn't find the order that they are on top of the motor, but a local auto store said as you look at the motor they go 4 3 2 1 is this right also?
WTB: 88-91 CRX Si
Old 11-23-2005, 04:45 AM
yes #1 is by the cam gear. but looking at the distributer from the pass. side it should look like
| 3 4 |
| 1 2 |
\____/
firing order is 1342
Old 11-23-2005, 12:41 PM
AF - Advisor
Re: Re: 1989 1.5 won't fire
| 3 4 |
| 1 2 |
\____/
the firing order is 4321 as mentioned above.
