Old 11-20-2005, 04:52 PM
unknownlogistic unknownlogistic is offline
Wont start
Ok well it was moking this loud noise...kinda like a car that was Camming with high power..but its just stock...well i turned the car off and checked the plugs and they were fine...the car then didnt start at all...its tries to but wont...i changed the spark plugs, ditribuot cap and rotor...the fuel pump is fine, wes tested it...but it still wont start. Also sometimes it smells like gas..What is it that i need to fix??? This is my only car and i need to it towrk...its a 1995 Honda Civic EX , d16Z6 motor.
Old 11-20-2005, 07:00 PM
frozen_Joth frozen_Joth is offline
Easily Distracted
Send a message via AIM to frozen_Joth
Re: Wont start
Did you put the spark plugs back in the right order? Or is the CEL light on?
'92 blue Civic Si
-B17a
-Carbon fiber intake, full exhaust
-Short throw, lowered
Old 11-20-2005, 07:08 PM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
Re: Wont start
put the spark plugs back in the right order??? You mean the plug wires?
Empty Pockets Racing Member #1
Old 11-20-2005, 09:01 PM
superbluecivicsi superbluecivicsi is offline
AF - Advisor
Re: Wont start
before doing anything to a car that cranks and doesnt start, the, fundamental things to check is spark, fuel, ignition timing, and cam timing.
99 [email protected] psi si- I voted for the Terminator for Gov.
95 HB- B16a2- SC34@12psi
WTB: USDM B16a2 or B16a3 complete short block. pm is the key.
FS: B series InlinePro cast mani, PnH RC 550s, and Hondata S2b. pm me.
Old 11-20-2005, 10:31 PM
could it be coil packs? i was told coil packs but i dont have a clue what that is ....how do i check the timing?
Old 11-20-2005, 10:52 PM
AF - Advisor
Re: Wont start
check ignition timing with a timing gun and make sure it is within specs.
as for cam timing, make sure cam gear is at TDC with the camshaft.
as for spark, check the spark plugs to see if they are recieving spark.
as for fuel, check to see fuel pump primes and injectors are working. check fuel pressure are within specs.
Old 11-21-2005, 07:10 AM
the spark plugs arent sparkinga at all...the fuel pump is fine...anything else ????i will check the rest today, hopefully something will work
Old 11-21-2005, 08:44 AM
i_a_n112784 i_a_n112784 is offline
Send a message via AIM to i_a_n112784
If there is no spark, then the main suspects are the coil, distributor cap and rotor. But you changed the cap and rotor, so I would check the coil. The coil not working right can cause the gas smell, because it's not sparking enough to combust all the gas.
Old 11-22-2005, 07:02 PM
Re: Wont start
ok well it was the ditributor...however it is idling funky still..kinda like when something cams...i was told its the sensor or something on the throttle body...what is it called? speed idle control or what???
