Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 11-20-2005, 07:42 PM
Eclipsewhipping Eclipsewhipping is offline
Question problem wit z please help
OK! my windsheild washer fluid jets, (the things that spray the windsheild washer fluid on the windows) are mest up. the back window sprayer doesnt spray at all, and on the front, the driver side jet sprays a lil, but very weak like, the passenger side jet sprays alot and very powerful, it seems all the fluid is coming out the passenger side jet, and when i push the button for the back window mist nothing sprays out, i filled the windsheild washer fluid tank up, and still have the same problem. any idea what could be causing this, and how much it would cost to fix, i would like to hear worst and best case scenarios,
thanks for the help again,
steve
Old 11-20-2005, 07:52 PM
-The Stig-'s Avatar
-The Stig- -The Stig- is offline
On Fire!
Send a message via AIM to -The Stig-
Re: problem wit z please help
Maybe the squirter jets are dirty? maybe try cleaning them out??
Not sure. I don't have those... wouldn't know what to do... But my guess is the jets might be clogged.
2003 Chevy 1500HD - Hauler
1971 Chevy Camaro RS - Track Car
User Guidelines It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here.
Old 11-20-2005, 07:53 PM
thats a possibility but is there any other suggestions?
Old 11-20-2005, 10:20 PM
Nissan-Fan's Avatar
Nissan-Fan Nissan-Fan is offline
What kind of car? on my first Z, the vinyl hose that ran across my firewall and fed the jets was very poorly replaced, it had leaks in it, and shitty Tee's.
Also, your washer pump could be pooched. Worst case scenario, replace the pump and the plumbing.
DIY it and it wont cost much at all, parts stores should have everything you need.
1978 Datsun 280z
2.8Litre Inline 6
T04 Turbocharger, Intercooled
N42 Intake Manifold
3" Downpipe
[Work In Progress]
Old 11-20-2005, 11:10 PM
its a 1991 nissan 300zx twin turbo
Old 11-20-2005, 11:24 PM
freakonaleash1187's Avatar
freakonaleash1187 freakonaleash1187 is offline
Send a message via AIM to freakonaleash1187 Send a message via MSN to freakonaleash1187
try cleaning out your jets. if that doesnt help, check all the tubes for leaks. if that doesnt help, replace the pump. if that doesnt help, im out of ideas.
ZedEx Crew Member #2
Old 11-20-2005, 11:35 PM
FixUrNissan's Avatar
FixUrNissan FixUrNissan is offline
steve
The Washer fluid nozzle is probabbly clogged.. remove it and try to clean it by either blowing air from the where the fluid comes out.. or there cheap enough to replace.. it's not the pump if one side sprays fine.. just double check line also make sure its clear and not kinked
Old 11-20-2005, 11:57 PM
is it one continuosly connected line for all three jets, the two front and the one back?
Old 11-21-2005, 10:31 PM
if it is one continous line, i think it might be a leak in the hose. could that cause my proble?
Old 11-21-2005, 10:45 PM
yes it could be the problem. the leak could be after the one jet that works really well.
Old 11-21-2005, 11:27 PM
but is it one continous hose that runs to all three
? by the way my washer fluid tank in in the back of the hatch
