Old 11-20-2005, 04:00 PM
StvnRowe StvnRowe is offline
2000 GP making creaking noise
My car just suddenly started making a creaking noise about a week ago and it has steadily gotten worse. Whenever I turn the wheel, accelerate, or brake it makes a creaking noise. I had my control arm bushings replaced because I knew they were shot, but that helped for about a day and the noise is back. I read something about motor mounts possibly being a cause of this problem, but that wouldnt cause the car to make noise when I turn the wheel at rest. Any suggestions as to what it could be?
Old 11-20-2005, 10:45 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 2000 GP making creaking noise
Sounds like the upper strut mount and bushing. Also check the anti-sway (stabilizer) bar link bushings at the control arm and mid-mount bushings.
Thrasher CAI, DHP v1.0 PCM, SLP Headers,
3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 72mm TB,
TB spacer, MSD 8.5mm wires, Autolite 103,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
1/4 ET: 13.210 sec. @ 104.490 mph
0 - 60 ft: 1.945 sec.
Timeslip 08/12/06
AF Community Guidelines
Old 11-21-2005, 01:16 AM
rbsteve rbsteve is offline
Silicone lubricant spray works wonders on small suspension creaks. Give a good coat to all the rubber bushings in the suspension and see if that helps.
Old 11-21-2005, 09:16 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
if you go the lubricant route, do them one at a time to isolate the offending part, but it sounds like an upper strut mount/strut bearing to me too.
