Old 11-18-2005, 04:08 PM
quadzero's Avatar
quadzero quadzero is offline
WIP: '57 Corvette prostreet
Hello all, hope to have more pics soon but this is it so far. The kit came with a conventional leaf rear suspension and the big tires stuck out about half an inch. I cut off about 1/3 of the chassis and scratched the rear frame and wheel tubs and fuel cell. I also made a new 4-link suspension which was a real bear.
I also made shocks and coils and its too bad they are hidden so much.
Another view of the 4-link. Still have to add the fuel and brake lines and do some touch-ups.
I had to do alot of work on the body and changed the part lines on the tilt front section and cut out the trunk lid too.
Im not totally sure what colour it will end up as but it will be close to the interior, pretty much the way it's depicted on the box top.
cheers
Old 11-18-2005, 04:13 PM
ol' dude's Avatar
ol' dude ol' dude is offline
Re: WIP: '57 Corvette prostreet
That is looking awesome!! Keep us posted on the progress!! It looks to be coming along nicely!!
BUILD TO SATISFY YOURSELF AND NO ONE ELSE!
Click to view ACME's website
Old 11-18-2005, 04:17 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
looks really good, keep up the good work
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 11-18-2005, 11:40 PM
white97ex's Avatar
white97ex white97ex is offline
Send a message via AIM to white97ex Send a message via Yahoo to white97ex
great work. those coil overs look awesome
My name is Russell, feel free to use it.
I'd rather be hated for Who I Am than be loved for Who I Am Not
Old 11-19-2005, 10:45 AM
AstroRide44's Avatar
AstroRide44 AstroRide44 is offline
can u get anymore detail pics of the rear end during progress? im thinking about doing this to my corvette too
"You can go far with a smile, but you can go farther with a smile and a flamethrower"
Keep it Wingless.....
Old 11-20-2005, 06:54 PM
eph2 eph2 is offline
Send a message via MSN to eph2
Wondefull Work!
Old 11-21-2005, 12:50 AM
quadzero's Avatar
thanks everyone. i was expecting to have more pics today but small problems kept me from painting the body and interior. ever have one of those days? and to top it off, i broke my last bit for my pinvise so the engine is on hold also. sorry, AstroRide these are the only pics i took so far but i recommend tackling the suspension all the same. it was just something i wanted to try for awhile.
Old 11-22-2005, 11:40 PM
quadzero's Avatar
here is the test fitting of the engine, its a small car but that 283 is soooo tiny sitting there. and the headers to me look silly, i spent hours sanding and filling sinkholes and getting rid of the molding lines and now it looks like a big spider sitting where the engine should be. might make new ones out of solder but im not too sure yet. the white part sitting in front of the car is part of the hinge for the tilt front end.
this is my scratch built dist. the top is from the scrap box and the base is sprue turned in my dremel as is the vacuum advance. it seems the older i get parts i make in 1/24 usually end up closer to 1/20 but i can live with it, lol.
Old 11-25-2005, 08:12 PM
quadzero's Avatar
hello everyone again. well after countless hours refining kit parts, digging thru the scrap box, scratchbuilding and crawling around the floor looking for parts that vanished from my tweezers, i finally have an engine. i will keep the headers afterall and locate the battery to the firewall somewhere. i wanted it in the trunk but there wasnt enuff room.
for the drive belts i carefully cut away the kit off center and poorly molded pulleys and made new ones or modified ones from my parts bin. i then painted them and glued them back onto the belts. the alt pulley was good and i left it alone. the belts were cut and small sections were taken out so the pulleys would line up on the crank and water pump and blower. as you can see this process isnt done yet and i still have to make an alternator and coil and lots of little details. dont have a rad yet and still looking for carbs.
cheers.
Old 11-25-2005, 08:49 PM
1986Z28's Avatar
Has a Camaro
THAT BLOWER BELT SHOULD HAVE AN IDLER PULLEY!!! sorry caps lock on
Old 11-25-2005, 09:01 PM
quadzero's Avatar
gee, thanks. like i said you can see this process isnt finished yet and the mount for the idler pulley is already on the blower. still looking for a suitable donor, or try to do something with the original one. but its back to renovating the house again for me now.
Old 11-25-2005, 09:54 PM
1986Z28's Avatar
Has a Camaro
ahh ok
Old 11-25-2005, 11:17 PM
white97ex's Avatar
looking good. I dont know if resin is an option for you. if it is, try www.bestresin.com their casts are VERY clean, and their prices are more than reasonable. they have some very nice carbs
Old 11-28-2005, 04:03 AM
quadzero's Avatar
little more progress, test fitting the hood. took a long time to align everything up but to my great surprise it closes perfectly. and not to my great surprise, when i put the engine in place the hood hits the blower belt so a little more surgery there. funny how it cleared before i had painted the hood.
a little more detail. soon i will be adding lines and the rad, turns out that this kit comes with 2 of them and one isnt that bad at all.
thanks for the great link, White97ex! wow talk about tons of goodies there. but i looked at the kit carbs again and i think i can do something with them, i will have a go at it anyway.
cheers all.
Old 11-28-2005, 12:21 PM
flying finn's Avatar
flying finn flying finn is offline
I´m really digging the chassis mods and the engine, but would have painted the body in a different colour
"Rat rod – Usually a hot rod with an excessive amount of patina and some less than ideal engineering principles"
