Go Back   Automotive Forums Car Chat > Toyota > Tacoma
Old 11-18-2005, 01:21 PM
TacomaPilot's Avatar
TacomaPilot TacomaPilot is offline
01-04 Maintenance Manual?
Has anyone found or seen an owners maintenance manual for the 01-04 Tacomas, like Chiltons or Haynes? I've been looking and haven't seen anything. I know there are some differences with the front end cosmetics between these and the previous model years, but would the manual for the older models work just as well?
Old 11-18-2005, 09:59 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 01-04 Maintenance Manual?
What don't you like about the 2003 Maintenance Manual in the sticky post at the top of this forum?
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 11-19-2005, 02:20 PM
The link isn't coming up from the sticky or my bookmark. I have referenced it before, but I wouldn't mind a more portable one. I'm just surprised one hasn't been printed that I've seen.
Old 11-19-2005, 02:34 PM
Brian R.'s Avatar
Resident Chemist
You're right. I'm having trouble with that site also. I guess I'm lucky I downloaded it.
Do you need a particular section?
Old 11-20-2005, 09:56 PM
Re: Re: 01-04 Maintenance Manual?
No, not right now. I haven't had any problems aside from my quarter window latch breaking on my xtra cab. Fortunately it still locks so I'm not too concerned, just like to have references just in case. At some point I'll order the part from tap recycling (http://www.taprecycling.net/) which appears to be a great used part place if you haven't seen it yet.
Old 11-21-2005, 07:28 AM
mtndw mtndw is offline
Unhappy Re: Re: 01-04 Maintenance Manual?
Good day Brian. No luck in getting the site to open either. I am looking for how to get the RH outer CV joint off the axle on an 03' for boot replacement. Seems like the type the you just tap off over the clip ring, but I've done a fair bit of "tapping" with no joy. Also thought it may be like a GM in which you drive the cage back out & start taking the balls out, but no luck that way either. I'm new to the Toyota section here & I will prowse this forum for some info as well. Txs
Old 11-21-2005, 09:34 AM
Txs much Brian. I guess by the look of what you sent me they don't want to take the outer joint apart, rather take the inner apart & slip the outer boot down over the axle...Tks again, Mtndw
Old 11-21-2005, 07:12 PM
Brian R.'s Avatar
Resident Chemist
You're welcome
