5.0 starting problem!!
i have a 91 5.0 and recently it has had problems starting.. I have a brand new Powermaster 140amp alt. brand new 6yr. battery, new msd ign cap, rotor, wires and plugs... i dont know wat the problam is.. my battery is dead everytime igo in the car even wen it was JUST running like 2 seconds before... the car starts up on jump so i dont think it could be the starter.. but who knows it might be.. someone please give me answers....also wen i am driving my volt gauge is really low and all my lights r dim but brightenup weni give it gas... i thought this was alternator so i bought a new one.. i don't kno...
SUPA-PRIX |
Re: 5.0 starting problem!!
the dim lights that brighten up when u give it the gas is the alternator test. but if u bought a new 1 i dont know what it could be
I've seen several new parts be bad. Have the alt tested. Starters and altenators are somewhat commonly bad when bran new. I went thrue 3 starters on a chevy before I got one that worked.
1969 Cougar 357w & TKO - 475hp |
Sounds like the voltage regulator is bad. Im not sure, but your car might have an external regulator versus one built into the alternator. If its built in then you got a bad part. If its external try changing it, theyre not too expensive.
"The Constitution shall never be construed...to prevent the people of the United States who are peaceable citizens from keeping their own arms." -Samuel Adams, 1786 |
If you've replaced the alternator than your voltage regulator should be fine, its inside the alternator.
Sounds like the solinoid on your starter is going bad. There like that when they start going bad. Sometimes they will start and sometimes it won't. The only way to correct the problem is to replace the starter.
Ported Cobra Intake, Ported & polished Windsor Jr heads, K&N, Vortech s-trim, 90mm Lightining mass air meter, 70mm throttlebody,1.7 roller rockers, BBK Long tube headers, offroad H-pipe, Crane cam, main cap girdle, 40 series flowmaster, 3.73 gears, MSD ignition, CGS subframes, A9L PIH kit, SCT custom burned chip, 42lb injectors, 190lph fuel pump, T rex and fuel pressure regulator, AFCO racing radiator (If it doesn't scare the Hell out of you it isn't fast enough) |
Sounds like a voltage drain too me. If the car starts right up with a jump.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper. |
Check for a bad ground. Either engine to chassis or more commonly, battery to block.
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex -1999 Ford F150 |
hey thanks guys, ya im pretty sure this alt. has a built in regulator, it is probably a voltage drain somewhere.. but i have so much shit in my car weather its my stereo or all my gauges i have a lot of bad grounds to check.. i will probably end up buying a new starter... anyone have any good suggestions of starters for me to get and prices, i noticed they vary depending on torque.. i have a few upgrades in my car new cam, cai, maf, headers, exhaust, ign., tb & egr so i dont kno wat kind of torque im playin with.....
SUPA-PRIX |
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world has lost one of the truly wonderful people...
