Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 11-07-2005, 10:27 PM
Camry99 Camry99 is offline
Send a message via AIM to Camry99
Question just got my bumper painted and sensors are coming up
I just got my bumper painted today. Since then, my tail lights flicker off and on (along with the icon in the display panel)......and no matter what drive I am in, the Reverse is lit up as if I was in reverse. The check engine light recently came on too. The guy at the shop said he has no idea. He said he didnt even unhook the battery.
Is this a sensor problem, bad wiring, or what? Thanks
Old 11-07-2005, 11:19 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: just got my bumper painted and sensors are coming up
Check the wiring in the trunk by the hinge. This can be frayed and periodically short out or ground.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 11-08-2005, 07:34 AM
this morning when my lights didnt go on (because it was day time), the icon with the tail lights out and the R icon were not lit up. When I turned my lights on manually it did go on. Thanks for your help Brian. I will check into it when I get home today.
Old 11-08-2005, 09:29 AM
Brian R.'s Avatar
Resident Chemist
You're welcome - good luck
Old 11-08-2005, 12:58 PM
driving home I was testing it out and turned my lights on and off. Everytime I did that, the tranny shifted funny each time I turned the light on for about 1 second. I don't get how that can happen from just turning lights on, but the reverse sensor was lit up so I guess that triggered it.
I am waiting for my dad to get home around 3ish to talk to one of his buddies who has a mechanic shop. If it is the wiring, how much would that cost to fix? Thanks
Old 11-09-2005, 01:35 AM
Toysrme's Avatar
Toysrme Toysrme is offline
AF - Advisor
Send a message via ICQ to Toysrme Send a message via AIM to Toysrme Send a message via Yahoo to Toysrme
Cool
The TCCU reads the reverse sensor in combination with other things to interpit what you want it to do.
It's concievable that when you trigger the reverse light, the TCCU actuates a solenoid in the valve body that may be actuating a brake, or trying to move a clutch around.
Causing it to act funny until it stops tring it to do that.
Then again I could be tottaly wrong & it's either in your head, or some other issue.
Toysrme257th - AIM about anything, anytime; including v6 turbos.
World's second ES 300/3vz-fe Turbo.
Old 11-09-2005, 04:01 PM
I took it to a transmisson shop and my dads friend said it could be a Neutral Safety Switch
Old 11-15-2005, 12:40 AM
Re: Re: just got my bumper painted and sensors are coming up
brian you were right, it was the wiring
thanks a lot man
Old 11-15-2005, 01:34 AM
Brian R.'s Avatar
Resident Chemist
You're welcome
