Old 11-07-2005, 03:27 PM
Captain Mark's Avatar
Captain Mark Captain Mark is offline
Problem with lacquer through airbrush - can anyone help?
Hi guys,
I've decanted (messily!) some Tamiya TS spray and started shooting it through my airbrush. I'm using Tamiya lacquer thinner, with probably a 3:1 paint/thinner ratio. Anymore seems to thin it too much so as to be a washy white thinners mix that's unsuitable for a topcoat.
Temp has been in low 20's (C), and humidity is about average. Shooting at about 35-40psi using reasonably new Iwata airbrush (cleaned regularly).
I'm finding that often when I shoot this stuff it can leave a VERY grainy appearance in some areas. On the odd occasion it's also as if rather than going grainy it sort of forms into little hair-like... 'things'. As if lots of small hairs fell on the job just as I was spraying.
On the heavier areas it's not there very much at all, which leads me to believe it could be a spray volume thing. But then it hasn't done it in all areas... and others have had success with mist coats, etc.
It's going to be impossible to spray a mist and final clear topcoat when I come to it if this problem persists (although currently shooting white).
Can anyone help me stop this problem???
I've got no more tricks up my sleeve.
Thanks all,
M
Old 11-07-2005, 04:11 PM
robrex's Avatar
robrex robrex is offline
Re: Problem with lacquer through airbrush - can anyone help?
I use a 'High Quality Laquer thinner' that I got from a local paint supply store. I had the same problem when I first started decanting the Tamiya paints. I ended up mixing the paint/thinner to about 50% mix. I also thought it was too thin but the thinners dry very quickly.
Rob
Old 11-07-2005, 04:15 PM
pettercardoso's Avatar
pettercardoso pettercardoso is offline
Send a message via MSN to pettercardoso
I've only decanted and airbrushed TS one time, but I've airbrushed it directly without thinning it and the paint was fluid enough through my Iwata HP-C @ around 20~25 psi.
Probably metallic colours may need a bit more pressure due to their "thicker" consistency...?
Pedro
Click the picture to check my progress thread:
Old 11-07-2005, 04:38 PM
mikemechanic's Avatar
mikemechanic mikemechanic is offline
Sounds like you are getting veiling due too your lacquer being too thick. Sounds like you need to thin more. Check out the tutorials on Cobra colors site. Very informative and helped me out immensley.
Old 11-07-2005, 05:01 PM
ZoomZoomMX-5's Avatar
Since you've already tried thinning the paint, try a much lower air pressure-you might get much better gloss starting in the 10-15 psi range-work up from there until you reach a happy medium-Tamiya spray decants w/o needing much thinner (if any) to work well through an airbrush. I think excessive pressure is causing the paint to dry much too rapidly before it hits the surface.
My Fotki Album
Old 11-07-2005, 05:26 PM
I think a bit more testing is in order - thanks for the tips guys, I'll give it all a go tonight!
Old 11-07-2005, 11:02 PM
SteveK2003 SteveK2003 is offline
Send a message via AIM to SteveK2003 Send a message via Yahoo to SteveK2003
There was an article on this in a recent Fine Scale Modeler: The author decanted some paint and sprayed on an overall mist coat lacquer straight from the can at about 10psi, and then when it cured he did a single wet coat with the can. He says he didn't do any finish work and it looked great.
Old 11-08-2005, 04:25 AM
I've tried adding more thinner, to a ratio of about 1:1 and the problem appears to have vanished!
Time will tell I suppose, I've got a bit more experimenting to do... but hopefully I'll find some success and have the body of this damn BAR finished this year!
