Old 11-06-2005, 11:01 PM
Bacoman Bacoman is offline
Cool 2600 Rpms to zero!!
I have a 1997 Grand Prix SE 3800 for the past two years and its been a great car. For the past two months I have been having a problem that I can't seem to figure out. It happens when driving on the hiway, the rpms will go from 2600 to zero, the car seems to downshift, sometimes thats all that happens but occasionally it shuts down. I put it in netreul and turn the key and it restarts and the rpms are back to normal.
Anyone have this type of experience.
I have a 2000 GP GT and have never had this happen.
Old 11-07-2005, 05:49 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 2600 Rpms to zero!!
Two possible causes, crank position sensor going bad or the speed sensor in the transmission. Start with the CPS.
Old 11-07-2005, 03:18 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I agree, it's more likely a crank sensor.
Old 11-08-2005, 01:10 PM
PerfesserCoffee PerfesserCoffee is offline
I've got the same problem and assume I need to replace the CPS on my 1995 Grand Prix GTP.
On Rock Auto, I'm given the choices of:
a. STANDARD MOTOR PRODUCTS PART # PC7
7X SIGNAL (CRANKSHAFT SENSOR)
b. ACDELCO PART # 213148 SENSOR, CR/SHF POSN2 BLAD TERM-SIDE OF BLOCK
c. ACDELCO PART # 213234 SENSOR,CR/SHF POSN 24X TO ECM-BEHIND BALANCER
What parts do I need to complete the task for my car?
Old 11-08-2005, 01:50 PM
richtazz's Avatar
On your 95, you'd be best off to replace both, as there is no easy way to determine which is causing your problem. The one behind the balancer is the most likely cause, but I'd change both.
Old 11-08-2005, 02:05 PM
Okay, thanks, richtazz! I'll do that.
Where is the one located that is NOT behind the balancer?
Still driving a 1995 Grand Prix GTP with 3.4 L DOHC V6!
Old 11-09-2005, 09:16 PM
the.dude's Avatar
the.dude the.dude is offline
I think the same thing is what I am experiencing. I'll be going do the road and there is something like a surge in the acceleration then my tach shows 0. The car still run fine and nothing else is dufferent that I can see. When I restart, everything is fine.
I have a 98 gtp 135k. Any help is apreciated.
Old 11-09-2005, 09:57 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Re: 2600 Rpms to zero!!
Sounds like classic 24X CKPS going South. Also sometimes the TRAC OFF light will illuminate when it cuts off in addition to the tach going to zero. Here's a procedure to give you an idea of the work involved if you prefer to DIY.
http://mykidz.net/GTP/CrankPosSensor.shtml
Thrasher CAI, DHP v1.0 PCM, SLP Headers,
3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 72mm TB,
TB spacer, MSD 8.5mm wires, Autolite 103,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
1/4 ET: 13.210 sec. @ 104.490 mph
0 - 60 ft: 1.945 sec.
Timeslip 08/12/06
AF Community Guidelines
Old 11-09-2005, 10:43 PM
the.dude's Avatar
TRAC OFF... how'd ya know?!? Now I have TWO reasons that this light comes on. I've had wheel hubs going out all around the thing. Every time I run over railroad tracks the ABS / TRAC OFF pops on.
Old 11-10-2005, 06:51 PM
the.dude's Avatar
ok, I got the harmonic balancer removal tool from oreillys and the dumb thing doesnt fit the car. not sure what to do now, I am a foot. Everything in this kit is too big.
Old 11-10-2005, 07:23 PM
BNaylor's Avatar
What's too big the puller or bolts? The one Autozone has fits.
Timeslip 08/12/06
Old 11-10-2005, 07:32 PM
the.dude's Avatar
the bolts were to big, and the puller has a pad on the end that won't fit in the balancer hole. auto zone has loaned theirs out. Guess I need to learn patience. Hard when you dont have a car!
Old 11-10-2005, 07:48 PM
BNaylor's Avatar
What a bummer! Sorry to hear that. I know what you mean....lots of patience.
I'm glad I have 17 Autozones within a 20 mile radius. One of them is bound to have the puller available. Oh well.
Timeslip 08/12/06
Old 11-10-2005, 10:32 PM
the.dude's Avatar
Just so you can all have a laugh at my expense...
I went to Autozone tonight in my wifes car to just buy the puller I need. I planned on getting everything I need to finish this job tonight so tomorrow, when I have no other vehicle here, I don't have to worry about it. Well, I get the puller with the right bolt (still wrong bolts for the 3 small ones by the way), Pay, get in the car...
It won't start.
Turned out to be the positive battery cable was badly corroded and it just needed cleaned out. But it was still quite a headache. Her 97 Monte Carlo has the battery buried under everything short of a cup holder.
While I am on it, does anyone know why the 'security' light would randomly come on in the Monte Carlo? I would ask in the forum, but compared to this one, it is useless. I am hoping it was related to the bad connection to the battery.
Old 11-15-2005, 11:27 PM
Re: Re: Re: 2600 Rpms to zero!!
[quote=bnaylor3400]Sounds like classic 24X CKPS going South. Also sometimes the TRAC OFF light will illuminate when it cuts off in addition to the tach going to zero. Here's a procedure to give you an idea of the work involved if you prefer to DIY.
Thanks for the detail instructions. Any idea on what the parts will cost to replace the CKPS?
