Old 11-05-2005, 11:05 AM
patoffspyder patoffspyder is offline
Compressor question
Hi guys!
I am looking to buy a compressor. There is this one who is not very expensive and I wonder if it's good.
http://www.canadiantire.ca/assortmen...=1131210216922
What do you think about this? 65$ Can, is it too expensive for what it's worth? Is it enough?
Thanks a lot!
Old 11-05-2005, 11:09 AM
Vric's Avatar
Vric Vric is offline
Re: Compressor question
65$ Can ? it's a steal.. Go for it.
Old 11-05-2005, 11:10 AM
freakray freakray is offline
AF Modelrater
Linky no Worky.
Most compressors will be fine, just be sure to add a pressure regulator and moisture trap.
AF User Guidelines
Old 11-05-2005, 11:13 AM
Thanks a lot for the fast answer.
Link is working from here, strange...
Thanks, I will buy it. I will try to find the moisture trap and the regulator too.
Jobmate 3-gallon Oil-less Compressor
* 25' recoil hose
* Comes with 5-piece accessory kit
* Ideal for inflation
* 125 max PSI
* 1-year manufacturer's warranty
Old 11-05-2005, 03:27 PM
SteveK2003 SteveK2003 is offline
Send a message via AIM to SteveK2003 Send a message via Yahoo to SteveK2003
I like the Paasche combo moisture trap & regulator: The gauge only goes to 60psi, so it's easier to get a more exact reading between say 12 and 15psi.
Old 11-05-2005, 03:42 PM
Vric's Avatar
The Compressor come with a regulator, you only need a moisture trap (and you might not even need one, it depend how much humidity you have where you live)
I just come back from CT near me, and this compressor was 134$, so look like it's a web only deal.
Go for it, it's a great one (better than the one I have )
Edit: The link don't work for others because you need a Canadian Postal code to see it. Here is a picture for those that can't see it:
Old 11-05-2005, 03:51 PM
AF Modelrater
That compressor looks great, comes with just about everything needed, as Eric said.
You can't lose by getting it.
AF User Guidelines
Old 11-05-2005, 04:48 PM
Thanks a lot for your help guys, gonna buy it tomorrow. After that, I will need to get an airbrush ;-)
I still don't know which airbrush to buy, I want a gravity feed one and I don't know if I need a dual action one or a single action. And which brand... This is complicated :P
And it's not a web deal, I want to Canadian tire this morning and was 65$ :-)
Thanks again, you guys help me a lot!
