Old 11-04-2005, 03:12 PM
NateTheGreat NateTheGreat is offline
help with rim/wheel size, tires, etc.
Hello, I just registered and own a 1998 grand prix with 131k miles.
My question is what size wheels/tires/rims can I fit on my car? I need some help picking out what size wheels/tires/rims would fit on my car (lug nut size, bolt pattern, etc). If anyone can help, it would be greatly appreciated, thanks!
- Nate
Old 11-04-2005, 03:20 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: help with rim/wheel size, tires, etc.
- Nate
The bolt pattern is 5 x 115mm. What is your current wheel and tire size?
Thrasher CAI, DHP v1.0 PCM, SLP Headers,
3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 72mm TB,
TB spacer, MSD 8.5mm wires, Autolite 103,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
1/4 ET: 13.210 sec. @ 104.490 mph
0 - 60 ft: 1.945 sec.
Timeslip 08/12/06
AF Community Guidelines
Old 11-04-2005, 03:39 PM
205/70-15 is the tire size, how do I go about checking the wheel size?
Old 11-04-2005, 03:49 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
your factory steel wheels are 15x6
Old 11-06-2005, 12:51 PM
Niq Niq is offline
I don't want my new tires to rub....
It would be extremely helpful if some ppl could post here the wheel sizes that have fit well on their 97-03 Grand Prix. Especially those with lowering springs.
I would appreciate any tips on the ideal wheel offset and wheel width that fit best on your car. I am looking to switch to a 245/45-18 tire size.
Thanks in advance for your help.
Niq
Old 11-07-2005, 06:40 PM
Niq Niq is offline
I’m bumping this thread to get some attention. From the best of my online research, this is what I know so far.
The original wheel and tire info as per what I have found online is …
Wheel = 16x6.5 +38mm offset.
Tire = P225 60-16
( For a 97-03 GP)
Since the wheel info didn’t come from GM itself, there is a slight chance it might be wrong. That’s why I am posting here for help.
Anyway, if you guys know of any wheel sizes, with tires that fit well under the car, I appreciate your help... ( Tire size plus wheel size as per above.)
Oh, and anything you know about “rolling fenders” would be cool too.
- Very appreciative new guy.
Old 11-07-2005, 11:45 PM
phaelax phaelax is offline
that info is correct, thats what is on my car
Old 11-08-2005, 05:56 PM
Niq Niq is offline
Re: Re: help with rim/wheel size, tires, etc.
Thanks for your help man. As I learn more, I'll post here. I hope that someone has some input on some different tire/wheel combos that fit ok....
Old 11-08-2005, 06:31 PM
jimmyv-21's Avatar
jimmyv-21 jimmyv-21 is offline
i put 17X6.5 on my 01 gt and it lowered it 1.7". if you dont get lo-pro tires you will have to do some fender mods. i will check what tire size i got- the 17" fill the wheel well much better then the 16", specially after the 1.7" drop.
Old 11-08-2005, 06:32 PM
jimmyv-21's Avatar
Old 11-08-2005, 10:28 PM
04GTP-WhatLAG?'s Avatar
04GTP-WhatLAG? 04GTP-WhatLAG? is offline
I plan on adding wheels to my 04' gtp after the 1st of the year(tax season), I'm going to go with 17X7.5 wheels...
As a matter of fact I have my eyes on these:
http://www.pfyc.com/store/merchant.m..._Code=04WHEELS
2004 Pontiac Grand Prix GTP
Custom K&N Fenderwell Intake , 180° thermostat, 3" Down Pipe, High Flow Cat, DHP 1.0 PCM, 3.5" pulley, 1.9 Ratio Roller Rockers, 90# LS6 Valve Springs, AL104s, ZZP Motor Mounts, 17" American Eagle 192s, Magnaflow tips.
not just babies whine
Old 11-10-2005, 07:24 AM
Niq Niq is offline
Thanks for the input. Much appreciated. I will not be using low profile tires. I want to maintain the same original outside tire diameter, so the speedo doesn’t suffer.
I’ve about talked myself out of 18” wheel/tires. I’m pretty sure I’m going to go back to 17” too. I have some 17” wheel info. I’ll post it here after work.
Old 11-10-2005, 08:10 AM
BNaylor's Avatar
If you planned on using the 245/45-18 tire/wheel combo, it should fit as long as the aftermarket wheel has the proper offset.
The stock tire width (footprint) is around 8.86". A 245 tire has around 9.65". That's less than a one inch difference. The diameter of stock is 26.83". 245/45 - 18 should have 26.68" so its a very close match. When the speedo reads 65, the car will actually be going approx. 65.2 mph. Plus the aspect ratio (tire height) is acceptable and they look good without having a SUV appearance.
Timeslip 08/12/06
Old 11-11-2005, 10:17 PM
Niq Niq is offline
Thanks bnaylor, for the help.
