| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
Timing belt trigger Check Engine light?
Thanks in advance for your help!
If my timing belt is approaching the end of its life, will the check engine light remind me? Again, thanks. GO WHITE SOX! |
Nope, you usually don't get much warning. It just sort of "goes". If you are N/A, don't worry about it. Chances are much less likely, and they are slim to begin with.
'92 3000gt SL Zoom Stage 1 Clutch Quote:
Check and see how tight the belt is and worn out and etc. Plus if you know the last date it was done you should know whether or not you need a change. Don't wait to do it like I did b/c my belt slipped on me and a rebuild cost me a shit load. There's no warning of any kind...it sort of just slips
![]() 05 Srt4 Agp 3147 w/supporting mods ![]() 97 Mx-5 T28, hks man, ebay int/pipes, rfl bov, xtd 6 puck, 3" magnaflow, msd timing box, |
Re: Timing belt trigger Check Engine light?
Re: Re: Timing belt trigger Check Engine light?
I replace mine every 50K, but i'm paranoid...
CEL wont show for a slipping belt. It only comes on when a catalyst efficiency harming fault code gets set. Or a body code. |
every 40k for me
I dunno I'm weird like that
now - 2000 civic soon - 2002 is300
There's no reliable way of knowing when it's going to go before it does. In the 2g both the turbo and n/t models run an interference style head. That means if the belt snaps you buy new valves. I had a belt that slipped once after I had the dealer replace it, when I first got the car. All bad.
I used to own a DSM. Quote:
I Just had my timing belt slip. Only had like 7000 Km's on it. Was a Brand new head on the car to, and a refreshened bottom end. Haven't really looked into it much though, been to busy. But there's no compression. So I'm guessing the valves are all bent to shit, or the ring's are shot.
