Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 10-24-2005, 10:56 PM
Dreamtwister Dreamtwister is offline
Changing an alternator on a dodge pick up
I think I have a problem alternator on my 1996 Dodge sport pick-up Can anyone give me somewhat detailed instructions on how to chnage it
Old 10-24-2005, 10:59 PM
93rollaracer's Avatar
93rollaracer 93rollaracer is offline
Send a message via AIM to 93rollaracer
Re: Changing an alternator on a dodge pick up
Ummm...remind why this is in the Toyota Corolla forum again?
Proud member of DAMM: Drunks Against Mad Mothers
Originally Posted by vinnym86
Metalheads: 93rolleracer
crazy sons of bitches who get hammered, break shit, and scream. yeah, they're pretty cool. right up to the point when they lynch a black guy.
Old 10-25-2005, 12:57 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Welcome to the AF!
In general, we post questions on vehicles in forums that relate to the vehicle.
Moved
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 10-26-2005, 07:34 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Dreamtwister, it's a pretty straightforward procedure.
First step is to remove the serpentine belt. The procedure is in your owner's manual, but basically you find the tensioner, put the right size wrench on it to relieve the tension, and slip the belt off. If you don't have the routing diagram for the belt, make one before you remove it.
Next, you'll do the swap on the alternator. There should be two bolts holding it in place, and some electrical connections. I'd do the electricals first, being careful not to break anything. Once you have that disconnected and out of the way, loosen and remove the bolts holding the alternator.
Installation is reverse of removal.
Good luck with it...
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 10-26-2005, 06:08 PM
Brian R.'s Avatar
Resident Chemist
Probably want to remove the negative battery cable first before you start removing connections from the alternator.
Old 10-27-2005, 07:02 AM
Whups yeah, thanks Brian.
