Go Back   Automotive Forums Car Chat > Hyundai > Tiburon | Tuscani
Old 10-24-2005, 07:08 PM
tyler1027 tyler1027 is offline
Send a message via AIM to tyler1027 Send a message via Yahoo to tyler1027
97 Hyundai Tiburon help?
I bought a 97 Hyundai Tiburon FX with 122,000 miles for 1,000 from a repo agent and found out it had a salvaged title. Well i just got the car painted. Was wondering if someone could help me with my transmission slipping. Going from 2-3000 rpms it revs high and then jerks back down to 2000 rpms. Whats the best way to fix it. Also wanting to improve the performance and was wondering what to do to start off. Not all the car smart but am loving to learn how to fix it up. Also would like to have it sound louder and just put on a magna flow muffler but the car still isn't very loud and was wondering what i could and should do to increase it. Any suggestions would be greatly appreciated. And will post some pictures for any other suggestions. Thanks Tyler
Old 10-24-2005, 09:39 PM
tibby01 tibby01 is offline
Re: 97 Hyundai Tiburon help?
congratulations!!!
your clutch is worn out.
i suggest replacing it with an aftermarket one, instead of a stock one. an aftermarket clutch will not increase power, but will provide more grip, putting more of your power straight to the wheels instead of slipping which just converts it to heat.
ebay has some clutches for our cars right now. havent really read any reviews, but i would give one a try if your not to pressed for money, they are CHEAP.
just watch out for the 4-puck ones. it will be insanely grippy, and not fun to drive around town everyday. you will stall often, or kill your tires within a couple months. will hold more power though generally.
while you are getting that replaced, you might as well get a aftermarket flywheel too. lighter ones will allow the engine to rev much more freely.
if you want to learn more about how cars generally work, www.howstuffworks.com and just get to reading. www.hmaservice.com/webtech is an online shop manual for all hyundais as well. i made up a universal login for everyone to use, but you will have to do some searching through these forums to find it.
Old 10-24-2005, 09:54 PM
Thanks
The only thing is its automatic so is there anyother suggestions you can provide. Anything is greatly appreciated.
Old 10-24-2005, 10:10 PM
oh, well then...
could be a bad torque converter. maybe even a tranny computer problem. good news is that you can swap to a manual transmission if you want to. its been done quite a few times with tiburons, and manual transmissions on ebay are CHEAP.
Old 04-20-2007, 11:20 PM
slamfreak slamfreak is offline
97 Hyundai Tiburon engine
I just bought a used 97 tiburon a little over a month ago and the thing put a connecting rod through the block so now i'm faced with putting in a new engine... i was wondering what kind of engines are interchangable with my car, i'm hoping for something with more power if possible.
Old 04-30-2007, 08:12 PM
bigd1180 bigd1180 is offline
Elantra motors are compatable dont know exact years but we got one out of a 99' Check with local salvage yards they can get you fitment!! Oh and about the tranny slipping problem the used auto trannys can run more then you paid for the car!!! These were not very good trannys and do not hold up to the abuse. So if you plan on beating on this car go the manual route or sell it.
Old 10-10-2007, 08:45 PM
HeadlessHorseman1 HeadlessHorseman1 is offline
Just out of curiosity, how much does a repair job for a slipping tranny go for on a '97 Tib FX?
Old 12-31-2007, 06:56 PM
97Tiburon 97Tiburon is offline
Send a message via AIM to 97Tiburon
hey man it sounds to me like you have a bad torque converter. easy to replace and not to pricey (at least for f-bodys) so shouldn't be to bad for you. also making it loud is not a good idea, throws you into a ricer cat. magnaflow is a good sound but not on an import, look into some other exhaust systems. good luck with your problems and hope it all turns out good for you.
Old 03-26-2008, 01:11 PM
Jepiza Jepiza is offline
what do you meAN?
