Old 10-24-2005, 04:47 PM
Racincc85's Avatar
Racincc85 Racincc85 is offline
Send a message via AIM to Racincc85
power steering fluid flush
I have a 1999 nissan altima with 115k on it. The power steering fluid is original and with me being a maintenace freak I want to change it. The flush wouldn't be all that hard because it has a remote reservoir. My question though is to whether or not to go with synthetic (the system uses transmission fluid). I am aware of what can happen when switching to synthetic in an engine i.e. leaks that are present can be made worse, etc. I have never done this with a power steering system before so I am not sure what would happen. It currently has no leaks so I wouldn't think anything would happen but I could be wrong. Thanks for the help!!!
Old 10-24-2005, 09:20 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: power steering fluid flush
Leaks from synthetic usually occur in engines with cork or paper gaskets. Since you're PS system uses flare fittings and O-rings it shouldn't leak.
Just pull the hoses off the reservoir and put them down in the drain pan. That won't get it all, but at least most of it.
Dragging people kicking and screaming into the enlightenment.
