Old 10-24-2005, 03:15 PM
Chevy4life1985's Avatar
Chevy4life1985 Chevy4life1985 is offline
Question Difference between 2ohm and 4ohm?
What is the difference between 2ohm and 4ohm? which hits harder? how do u wire them (Different setup?)
Originally Posted by veknyc1 on Sherdog.net
my man, picking up drunk jersey girls is like being employee of the month at mcdonalds
You to read this
http://www.sherdog.net/forums/showth...1&page=1&pp=20
Old 10-24-2005, 11:23 PM
germanyt germanyt is offline
Re: Difference between 2ohm and 4ohm?
neither hits harder. depending on how you wire will effect how much power you draw from your amp. this will depend on your amp as well. dual voice coil speakers expand your wiring options to better match a particular amp. just as and example, my amp is 800w x 2 @ 2ohms. what that means is that if my speaker is wire to 2 ohms and i hook it up I will draw 800 watts. same with the 2nd channel. with the same amp, if i wire the speakers to 4 ohm each and hook them up i will get 400 watts, 8 ohm would get 200 watts (roughly) if i were to run one sub at 4 ohm and use the positve from channel one and the negative from channel two (aka bridged) i would get 1600 watts. i mave have made this sound more complicated than it is but i hope i helped. check out rockford fosgates website for wiring diagrams, they have a good printer friendly page
(2) RE SX 15s (www.reaudio.com)
~6.5^3 net @ 35 Hz (polyfilled to increse vol. & lower tuning to 32 Hz)
(2) eD Nine.1s (www.edesignaudio.com)
1 Optima yellow top (www.optimabatteries.com)
1 Optima red top
200 amp alt (www.dbelectrical.com)
eDead V1SE2 250 sq ft
Big 3 (1/0 awg)
Pioneer DEH-P650 (www.pioneerelectronics.com)
Infinity Reference 5 1/4 comps (www.infinitysystems.com
Infinity Kappa 6x9s
MTX Thunder 3404
Power Acoustik TFT/LCD
Pyle DVD/CD/MP3/WAV/WMA player
Old 10-25-2005, 12:23 PM
Re: Re: Difference between 2ohm and 4ohm?
Na it helped thanks. I have a Audiobahn 1600x2 4 ohm. It says the 2ohm is N/A. So i grab the the + from channel one and - from channel two correct? See ive had plenty of sound systems but my buddy would wire it for me cuz i very felt like doing it. Now i started building custom boxes for my car and it would be nice to do the wiring myself. Thanks for the help.
You to read this
Old 10-25-2005, 05:11 PM
AudioGuy93DelSol's Avatar
AudioGuy93DelSol AudioGuy93DelSol is offline
NA is Best!
Send a message via AIM to AudioGuy93DelSol
Depends on the sub's impedance and wattage ratings.
Oil leak? What oil leak? That puddle under the car is just sweat from all that horsepower.
"How many NASCAR passes is that worth? 500?" (Schumacher passing Raikkonen)
Emily is amazing, and she messed with my sig AGAIN!
