Go Back   Automotive Forums Car Chat > Ford > Mustang > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 10-24-2005, 11:04 AM
nitrous36 nitrous36 is offline
Bigger Injectors
how much horse power can bigger injectors add?
Old 10-24-2005, 11:25 AM
Mines69Olds's Avatar
Mines69Olds Mines69Olds is offline
Send a message via AIM to Mines69Olds
Re: Bigger Injectors
It depends. Is that all you are going to do? It would be good to get a performance chip with it. If you aren't going to do too much with the engine you should'nt get that big of injectors too.
Old 10-24-2005, 04:54 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Adding more fuel without adding more air= rich condition and nothing else. Bigger injectors do not add HP!!!!!!
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 10-24-2005, 05:50 PM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Bore wash
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 10-24-2005, 10:36 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: Re: Bigger Injectors
Originally Posted by SkylineUSA
Bore wash
LMAO!
Nothing like the smooth mirror finish of washed cylinders
1969 Cougar
357w & TKO - 475hp
Old 10-24-2005, 11:58 PM
I know thats something you would want to do after adding a super charger. I have only added a cold air intake but there really isnt a significant increase in air from that to add bigger injectors. I was just curious with the idea.
Old 10-26-2005, 02:45 AM
GTStang's Avatar
Stang Guy
Bore wash
Haha
The real performance is "fuel wash" nothing like dumping fuel behind your compression ring and then igniting it for 1/4 mile times!
Old 10-26-2005, 02:47 AM
GTStang's Avatar
Stang Guy
You got a ways to go before needing bigger injectors you haven't even raised you duty cycle of em close to something to worry about.
Old 11-01-2005, 10:24 AM
camaroincal camaroincal is offline
Send a message via Yahoo to camaroincal
Would I benefit from bigger injectors if I have p & p Cobra heads + p & p upper & lower GT-40 intake + Moroso cold air intake?
Old 11-01-2005, 02:34 PM
SkylineUSA's Avatar
What injectors and cam do you have right now?
I really don't think you would need bigger injectors, porting the heads and intake are only going to be good for around 30-40hp
Old 11-04-2005, 08:34 PM
p0pcornplayer p0pcornplayer is offline
Send a message via AIM to p0pcornplayer
the only reason i got bigger injectors is because i had gotten a Kenne Bell supercharger, bored out, cams, pistons and entire fuel system. I dont see any reason why you cant. depending to what you have done and to what extent you should be looking at a mid 30'd improvement. + - a little.
Old 11-05-2005, 10:52 AM
SVTcobra306's Avatar
SVTcobra306 SVTcobra306 is offline
Not to contradict anyone, but if you went from a stock motor to P&P'd GT-40 heads and a Cobra intake and you have a full exhaust then it wouldn't hurt to upgrade to 24 lb injectors. I've done it on every H/C/I swap I've done....
1994 SVT Cobra. 306, Ported GT-40X's, Crane 2031, NX Wet Kit (100 shot for now),TKO 500, TwEECer R/T, and all the bolt-ons.....
http://www.cardomain.com/id/mccobra94
1995 F-150 SC/4X4 351W/E4OD, K&N, Custom Exhaust w/Flowmaster.
Freedom Isn't Free.
Old 11-05-2005, 01:10 PM
BigDanTheMan's Avatar
BigDanTheMan BigDanTheMan is offline
I read and am helpful.
Send a message via AIM to BigDanTheMan
i understand that stock injectors are good for about 350hp before you should consider upgrading them.
free hypsi87!!
Dan's White Horse
Bring back Melt Crew 002 - 3657 posts can't be wrong!
Old 11-06-2005, 05:06 PM
More like 300 for 19's.
Freedom Isn't Free.
