Old 10-21-2005, 09:33 PM
bawolvesfan's Avatar
bawolvesfan bawolvesfan is offline
ram air benefit?
hey ive got a taurus gt(modified gl) and i was wondering if it would be more beneficial to put a cone filter in my fender well or if it would be more useful to run tubing from my stock air box with a k&n as a ram air.
i have a functional hood scoop as well but i dont think i want to run my air intake there cuz of water problems. so wat do u guys think?
sry but ram air is kinda like forced induction right?
Old 10-21-2005, 10:48 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: ram air benefit?
ram air is not forced induction, its just a gimmicky way to say cold air intake. You would have to be driving well over 100 mph to come close to "compressing" any air.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 10-21-2005, 11:04 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
ram air system like the pontiac trans am and grand am dont really "ram" or force more air into the engine. Its just a way to draw colder air.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 10-22-2005, 12:33 AM
ok, that makes sense, but is the answer ram air and current box and filter, or cone filter in fender?
Old 10-22-2005, 01:38 AM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Ram air is not a form of forced induction.
Having a cone filter in your fender is just as good.
Old 10-22-2005, 09:15 PM
dogbreath077 dogbreath077 is offline
Put the aftermarket filter in the stock air box. The stock airbox is designed to draw cold air. If you draw underhood air, you lose horsepower due to the temperature of the air 300F. If you put the filter inside the fenderwell, then you get a lot of dirt on the filter.
Old 10-22-2005, 10:14 PM
Black Lotus's Avatar
Black Lotus Black Lotus is offline
As an aside---
Ram air is a form of forced induction, but it's at an extremely low level of effectivness. The F1 cars of the early to mid seventies used high airboxes to ram air into the intakes. It is so difficult to implement a genuine ram air system, and the speeds required are so high to make it work, that it's best to just shoot for cold air and leave it at that.
Old 10-23-2005, 01:42 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
Re: Ram air benefit?
a well designed ram air can, however, remove vacume from the intake manifold.
Old 10-23-2005, 05:07 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: Re: Ram air benefit?
Yeah, but only at WOT and 150 mph. There is always vacuum in the manifold at less than WOT.
Dragging people kicking and screaming into the enlightenment.
Old 12-18-2005, 04:17 AM
kachok25 kachok25 is offline
I read a figure once that a properly set up ram air induction only increases air pressure by 1-2% at 100mph that figure makes it virtualy non-existent (about .15-.3psi) even at excessive highway speeds unless you are doing 200mph on the autoban, and even then would not be a huge difference 4-8% and that is only if you have a perfectly setup airbox. If you really want forced induction stick with a turbo or supercharger.
Old 12-18-2005, 12:30 PM
Reed Reed is offline
Send a message via AIM to Reed
we had a VERY in-depth thread about whether or not certain things are froced induction. it was my opinion that unless it was mechanical it wasnt forced induction. I dont want to bring that back or start it over in here but it might help you decide if you think ram air is forced induction if you can find it.
Cars are like music.
If it ain't fast it ain't shit.
Old 12-18-2005, 12:49 PM
beef_bourito's Avatar
beef_bourito beef_bourito is offline
ram air can help remove some of the vacuum in the intake. whether or not it's worth even 1 hp is dependent on speed and the setup.
At the very least you'll have a cold air intake if you go the ram air way and you can tell your buddies that you have a working ram air hood.
Old 12-18-2005, 02:28 PM
It look prety darn cool that is the absolute best thing about it.
