Recently I have this clicking on my steering wheel when I'm making a turn. It's actually pretty loud and really scary especially when I'm breaking at the same time. Anybody knows what that is and how to fix it???
Re: steering wheel clicking....99 gp se
There is a known issue with the lower pinion bearings on Grand Prix rack and pinions. There was a recall involving this issue and your car may be covered. Call your area GM dealer with your vin and see, otherwise, get the car to a repair shop and have it looked at, as you're bound for an accident if it fails completely.
Do I really have to replace rack and pinion, is there any way I can fix it? It started just after I replaced wheel hub, maybe during installation of new hub I somehow damaged steering??? Any ideas?
![]() Thrasher CAI, DHP v1.0 PCM, SLP Headers, 3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT, u-bend delete, 160 TS, ZZP Stage 1 72mm TB, TB spacer, MSD 8.5mm wires, Autolite 103, Goodyear Gatorback Serp. & SC Belt, Nitto NT555R Drag Radials 1/4 ET: 13.210 sec. @ 104.490 mph 0 - 60 ft: 1.945 sec.
Re: Re: steering wheel clicking....99 gp se
[quote=bnaylor3400]I'd say your steering may be OK since you just changed the hub. It sounds like the CV joint to me. Especially with the clicking sound on a hard turn. How did you torque the axle nut and how many ft-lbs?
Axle nut according to Chilton manual should be 150 ft lbs. I did 160 ft lbs. Besides that my steering wheel is shaking while driving 60 - 65mph. You're aying I could damage CV joint while taking off axle nut?? |
If you used an impact wrench on the axle nut, you damaged the new hub, and that's where your click is coming from. Also check the instructions that came with your hub, as changes in bearing design can necessitate a new axle nut torque spec. Follow the torque spec included with the new hub if it differs from the repair manual spec. The aftermarket hubs we carry where I work (PTC), specify a torque of 180ft/lbs, just for reference
Re: Re: Re: steering wheel clicking....99 gp se
Next, simply taking off an axle nut should not cause your problem, however, changing a complete hub could and it sounds like you are getting side effects or an exacerbation of maybe a part that was worn out. How many miles were on your GP? Remember the axle/spindle is connected to the axle half shaft via the CV joint. The question you have to ask yourself is did you have that problem (noise) before replacing the hub? ![]() Thrasher CAI, DHP v1.0 PCM, SLP Headers, 3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT, u-bend delete, 160 TS, ZZP Stage 1 72mm TB, TB spacer, MSD 8.5mm wires, Autolite 103, Goodyear Gatorback Serp. & SC Belt, Nitto NT555R Drag Radials 1/4 ET: 13.210 sec. @ 104.490 mph 0 - 60 ft: 1.945 sec.
Re: Re: Re: Re: steering wheel clicking....99 gp se
[quote=bnaylor3400]The torque values in Chlitons and the GM service manual are similar at 151 ft-lbs for OEM. However, what brand hub and bearings did you install. The manufacturer of the hub is supposed to provide the new torque value. I've seen em as high as 180 ft-lbs.
Next, simply taking off an axle nut should not cause your problem, however, changing a complete hub could and it sounds like you are getting side effects or an exacerbation of maybe a part that was worn out. How many miles were on your GP? Remember the axle/spindle is connected to the axle half shaft via the CV joint. The question you have to ask yourself is did you have that problem (noise) before replacing the hub? There is already 142000 miles on this car. There was no noise before. I replaced the hub (right one) just because of speed sensor (my ABS was't working). If it's CV joint, what do you have to do to damage it? |
Re: Re: Re: Re: Re: steering wheel clicking....99 gp se
I had a friend who beat on the end of the spindle to get it separated from the hub. He also beat on the hub assembly. As a result the outer Rezeppa CV joint was damaged. Rich suggested that you may have defective bearings. What brand did you put in? ![]() Thrasher CAI, DHP v1.0 PCM, SLP Headers, 3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT, u-bend delete, 160 TS, ZZP Stage 1 72mm TB, TB spacer, MSD 8.5mm wires, Autolite 103, Goodyear Gatorback Serp. & SC Belt, Nitto NT555R Drag Radials 1/4 ET: 13.210 sec. @ 104.490 mph 0 - 60 ft: 1.945 sec.
Re: Re: Re: Re: Re: Re: steering wheel clicking....99 gp se
Re: Re: Re: Re: Re: Re: Re: steering wheel clicking....99 gp se
How well does your Chilton's cover the axle shafts and CV joints? I've got the GM service manual and it's specific to the Grand Prix. I could sent you what I have which includes illustrations via email. It calls for two methods. Visual inspection. But to do this you have to remove the boot cover. There is also a measurement and adjustment procedure that can be performed to make sure the CV joint is not stressed and in proper alignment. ![]() Thrasher CAI, DHP v1.0 PCM, SLP Headers, 3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT, u-bend delete, 160 TS, ZZP Stage 1 72mm TB, TB spacer, MSD 8.5mm wires, Autolite 103, Goodyear Gatorback Serp. & SC Belt, Nitto NT555R Drag Radials 1/4 ET: 13.210 sec. @ 104.490 mph 0 - 60 ft: 1.945 sec.
It's not impossible that you got a bad hub, but BCA is a good brand. I would look at the cv axle also, but if the situation worsened after changing the other bearing, I'm still leaning toward a bad new hub.
Possible bad BCA hub. Heaven forbid. I learned a long time ago to stay with OEM GM parts even if it means getting them out of a boneyard. ![]() I sent him some documentation. We'll see what he determines. BTW - What is the axle nut torque value for a BCA hub? ![]() Thrasher CAI, DHP v1.0 PCM, SLP Headers, 3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT, u-bend delete, 160 TS, ZZP Stage 1 72mm TB, TB spacer, MSD 8.5mm wires, Autolite 103, Goodyear Gatorback Serp. & SC Belt, Nitto NT555R Drag Radials 1/4 ET: 13.210 sec. @ 104.490 mph 0 - 60 ft: 1.945 sec.
