Old 10-18-2005, 11:26 PM
jretzlaff jretzlaff is offline
Send a message via MSN to jretzlaff
Best Spark Plugs?
What are the best spark plugs to use on a 00GT with would will soon be some minor mods?
3.8L L36 65k
Old 10-18-2005, 11:53 PM
I'm finding that the AC Delco Double Platinum is the best? But i'm also seeing a lot about Iridium? All the propaganda for it sounds good, but is the performance as good as the hype?
Old 10-19-2005, 06:05 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Best Spark Plugs?
Stick with the AC-Delco 41-101 Iridiums, unless you change them often while at the drag strip.
Old 10-19-2005, 09:35 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Just out of curiosity, what data have you found that claims the AC Delco Double Platinums are the best?
Thrasher CAI, DHP v1.0 PCM, SLP Headers,
3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 72mm TB,
TB spacer, MSD 8.5mm wires, Autolite 103,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
1/4 ET: 13.210 sec. @ 104.490 mph
0 - 60 ft: 1.945 sec.
Timeslip 08/12/06
AF Community Guidelines
Old 10-19-2005, 10:48 AM
Re: Re: Best Spark Plugs?
No data, just two mech shops in town telling me thats the best ones to use for my car. But from what I'm gathering now the AC Delco Iridiums (or some kind of iridiums) are the best. Does that sound right? What do you run?
Old 10-19-2005, 11:04 AM
BNaylor's Avatar
Re: Re: Re: Best Spark Plugs?
If you're stock go with the 41-101 Iridiums as everyone has suggested. They are the standard OEM plugs now. I use them in my Regal GS and son's Alero GL2. In my GTP I use Autolites but I'm modded. BTW - When the AC Delco 41-101 Iridiums were first introduced a few years back they were actually made by NGK. The 41-101 in my Regal GS has NGK stamped in the base below the ceramic.
Timeslip 08/12/06
Old 10-19-2005, 12:21 PM
blazindave blazindave is offline
yeah, i noticed that too -> NGK stamp on the base... I had wondered about that
1998 Pontiac Grand Prix GTP
3800 Series II V6
3.5" Supercharger pulley
