Old 10-17-2005, 07:14 AM
T66's Avatar
T66 T66 is offline
Power loss
How big role does the intake manifold play on a N/A application? Would it be possible (with an unskilled designed one) to loose hp. To be more specific, would it be possible to loose in the region of 18hp on a 2l 16v engine ?
English is not my first Language.
Old 10-17-2005, 11:17 AM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
intake manifold design is VERY important. With a piss poor manifold, yes i think its possibly to lose that much hp. Air velocity, equally length manifold runners, all play an important role.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 10-17-2005, 11:25 AM
T66's Avatar
T66 T66 is offline
Re: Power loss
What an answer. Thank you. I didn't even know of things like "Air velocity, equally length manifold runners....." Would you please be so kind to elaborate a little bit, especially on air velocity and equally length manifold runners. Just a little bit. Where would I be able to find more info?
Old 10-17-2005, 12:50 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
In a nutshell, the air in an intake manifold has mass. Every time the valves open and close that mass of air has to move and then stop. If they are all not equal length intake runners, their inertias are different and one cylinder will get less air while another will fill more fully. There are manifolds with different length intake runners, but the manufacturer has the benefit of billions of dollars worth of test equipment and computer modelling to make sure that it doesn't cause abnormal flow qualities.
As a general rule, as you lengthen or narrow intake runners, they favor low RPM torque production. As you shorten or widen intake runners they favor higher RPM torque peaks. This effect is less in Multiport EFI because the mass of the air in the runners doesn't carry fuel with it. With a carbureted or Throttle-body injected intake, the gasses moving through the runners is heavier since it carries fuel with it and the affect it has on the physics in the manifold is increased.
Another general rule is that as you increase the size of the Plenum, it favors higher RPM torque peaks, but again, this effect is minimized with MPFI
Dragging people kicking and screaming into the enlightenment.
Old 10-17-2005, 01:10 PM
T66's Avatar
T66 T66 is offline
Re: Power loss
Thank you again. This information is very informative. Just one quick question. Doesn’t the air get sucked into the engine causing an equal distribution of air into all intakes?
Old 10-17-2005, 01:45 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Re: Power loss
Are you able to post some pictures of your set up?
First of all Im curious, Im always interested in home made custom work, it shows a lot of intiative.
Second of all it will us have a better idea of what it is your doing, and may give us some clues as to whats going wrong.
Old 10-17-2005, 03:06 PM
T66's Avatar
T66 T66 is offline
Re: Re: Power loss
Sure thing. Will take a pic in the morning (seeing that it is like 22:06 Monday) and I will then post it during the course of tomorrow. Here is a pic of my project ride. It is a Nissan LDV RWD application with a weight of plus minus 650kg's. Forced induction will follow soon.
http://img.photobucket.com/albums/v4...Picture036.jpg
Old 10-17-2005, 08:52 PM
CBFryman's Avatar
CBFryman CBFryman is offline
Banned
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
Re: Re: Power loss
i could relate all this to some crap even i wouldnt completely understand to helmholtz's stuff.
but i am too tired.
for a more refined approach, try this, think of a 4cyl engine as 4 individual motors sharing a common crank shaft and air source.
each piston must pull its own air... lets make your lungs piston 1 at TDC right before the intake stroke, go get a smaller straw, bigger than a coffe stirer but larger than thoes fat assed things they use at mickey D's something you can feel resistance to sucking.
suck with all your might untill you cant suck anymore (air that is) now cut the straw in half and repeat... notice a difference?
Old 10-18-2005, 12:32 AM
T66's Avatar
T66 T66 is offline
Re: Power loss
10 / 4
Old 10-18-2005, 06:04 AM
zagrot zagrot is offline
Send a message via Yahoo to zagrot
Re: Power loss
CB has given you the key to the knowledge that you seek; helmholtz's work applies greatly to the design of an intake manifold, and to to exhaust design as well (though i'm still not sure if stock exhaust resonators are intended to attenuate noise or help exhaust flow). research "helmholtz resonator" and after a but of reading curtis' post will make even more sense to you. the major problem with intake and exhaust resonance is that the effect helps only in a narrow region of of the engines rpm. i once found a whitepaper on the design of an "active" helmholtz resonator which used a viberating diapharam in conjunction with a microphone in the resonator chamber, and controlled by an opamp, to cause the chamber to resonate outside of its tuned frequency. it is unfortunate that i lost the url, and i don't know if i downloaded the file; at least i printed a hard copy.
Old 10-18-2005, 07:16 AM
Re: Power loss
found it! if you don't understand the math don't worry. an engineer i showed this to said the math did not matter so much if you just want the gist of the idea, and it is an interesting alternative to the dual runner design.
http://www.egr.msu.edu/~radcliff/LabWebPages/home/papers/SmartHR.pdf#search='active%20helmholtz%20resonator '
Old 10-18-2005, 12:50 PM
T66's Avatar
T66 T66 is offline
Re: Power loss
Guys, here are some pics of my intake. Please note that it is a project car and that we are still in the process of making it looking good as well as being strong as well.
http://img.photobucket.com/albums/v4...Picture013.jpg
http://img.photobucket.com/albums/v4...Picture012.jpg
http://img.photobucket.com/albums/v4...Picture011.jpg
Moppie, please be so kind to advise.
Old 10-19-2005, 03:14 AM
Moppie's Avatar
Master Connector
Re: Re: Power loss
Listen to Curtis and the other guys, they are the ones who know what thier talking about
From what I can see the manifold looks pretty good.
Possible things I can see causing a problem are:
Inlet running length, they are very short.
Plenum chamber size, is it big enough?
Intake running to Plenum Chamber join, is the angle to sharp? does the air have to make a radical change in direction?
Did you do any resurch into manifold design before building it?
They are an interesting mixture of science and art and require a lot of thought to make them work right.
What did the engine come out of?
If its the one I think it is, then its from the same family of enignes that are in the MX5, Famila/323/Astina/Laser and 626/Telstar.
If so you might find that a Manifold from an MX5 will fit, or may require some small modication to the inlet runners to fit larger ports on the 2.0L head.
Or, it might give you some idea of the design you should be copying, in terms of runner length, plenum size etc.
Old 10-19-2005, 11:12 AM
T66's Avatar
T66 T66 is offline
Re: Power loss
Plenum to small. Got sorted out. Thanks guys.
Old 10-19-2005, 11:35 AM
Re: Power loss
it appears that you have great metal fabrication skill, the intake looks good. i went digging through some of the stuff that i found when researching intake manifolds and subwoofer design, you'd be surprised how similar the two subjects are. here is some stuff that is actually usefull.
this one is a good reference:
http://www.grapeaperacing.com/GrapeA...ionsystems.pdf
though i don't think you need guidance with the metal work aspect of fabricating a manifold, this site has pictures of the fabrication process. note the use of velocity stacks at the end of the runners.
http://www.themininut.com/inlet.asp
also since you said that you plan to install some type of forced induction device the manifold specifications will be less critical, though a tuned runner length would be beneficial. you would probably have been more pleased with your creation if a turbo charger, i'm asuming, was already in place.
