Old 10-17-2005, 07:12 AM
cbengtso2000gp cbengtso2000gp is offline
Question Front Hub assembly and CV/Halfshaft
Hello all,
This is the first time that I have tried this site out. I have a 2000 Grand Prix GT and just finished putting a front hub assembly on the drivers side. The installation was back breaking but everything went very smooth. When I took it for a test drive I now have a popping or cracking noice when I turn and accelerate. Can anyone help!!! Is this the half shaft or CV.
Thank you,
Old 10-17-2005, 08:37 AM
maxwedge maxwedge is offline
A990 racer
Re: Front Hub assembly and CV/Halfshaft
Make sure the axle nut is "torqued to 240 psi.
Old 10-17-2005, 09:16 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Re: Front Hub assembly and CV/Halfshaft
Max, are you sure about that?
Thrasher CAI, DHP v1.0 PCM, SLP Headers,
3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 72mm TB,
TB spacer, MSD 8.5mm wires, Autolite 103,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
1/4 ET: 13.210 sec. @ 104.490 mph
0 - 60 ft: 1.945 sec.
Timeslip 08/12/06
AF Community Guidelines
Old 10-17-2005, 10:24 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Sounds a little high to me, I think it's more like 180ft/lbs. In any case, make sure you tightened the spindle nut to spec.
