Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 10-16-2005, 05:27 PM
pimpn8ez301 pimpn8ez301 is offline
Brake Light Switch
My car was stuck in park so i checked the brake switch and noticed that one of the wire that connect to the connector, which connects to the brake switch was unattached how can i fix this
Old 10-16-2005, 05:33 PM
ModMech's Avatar
ModMech ModMech is offline
Re: Brake Light Switch
You can simply cut the other wire, remove the connector from the switch and install a "crimp-on female spade terminal" on each wire, then push it onto the "male spade" terminal on the switch.
Old 10-16-2005, 05:36 PM
Re: Re: Brake Light Switch
Ok what is a crimp-on female spade terminal and what is a male spade terminal?
Old 10-17-2005, 05:35 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Or you can buy the connector from Ford and replace the connector.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
