Old 05-20-2002, 01:09 PM
MKS MKS is offline
Standard Stereo
Does anyone know how to remove the standard stereo, I aint had a proper look yet i just wanted to know .
1989 Toyota Supra 3.0i Turbo
150mph I think I'm nuts
Custom S/S Exhaust 5" Tailpipe
K&N Induction kit
Bailys Piston Dump Valve (WOOSH)
Wategate Shimmed by 5mm ummm boost
Old 05-20-2002, 01:13 PM
darolh darolh is offline
Have a proper look. It's easy.
Old 05-20-2002, 01:30 PM
MKS MKS is offline
Haha ok I should really stop being lazy I'll take a look tomoz as its a bit dark now
K&N Induction kit
Old 05-20-2002, 04:10 PM
sarujin's Avatar
sarujin sarujin is offline
Okay from this is from memory so it may not be right.
First disconnect the negative battery part.
Look behind your stereo (you shouldn't have to remove the console, just lie on the floor), there should be one or two bolts in the back of it. Just find something which fits them, and undo them. I think then you can just slide the stereo out, because they don't use ISO connectors.
sarujin
Real Car: 1990 Honda Civic Hatch
R/C Cars: M-01, M-03, Pro3 & Xpress
standard stereo fuse problem indiginal Maintenance 1 09-04-2006 05:49 PM
Standard Stereo Removal! mixnting IS200/IS300/IS350/Altezza 1 01-21-2006 01:18 AM
Facia plate replacement to fit standard Stereo Potts Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 10-01-2004 08:29 AM
Standard stereo davetrousers Mégane 1 01-09-2004 05:31 AM
