Hello
My girlfriend has a 1.6 Megane, it still has the original stero. There are wires in place for rear speakers., but when i wire them up no sound comes through, I have checked the fade. Are there some wires on the back of the stereo that need connecting. Also how do you remove it there are a couple of holes, do you just stick a bit of wire coathanger in them? Finally is there a code for it? if so we cannot find the number, is there a way to find it out? thanks |
Check to make sure the wires are connected to the correct ports on the speakers.
As for removing the stereo, you should use a special key for this, if you don't have one, most dealerships will. And as for the code, go to any renault dealership, give them your cars registration number & show them proof that it is your car and they will provide you with a code there and then. Hope this helps.
Its not how fast you drive, its how you drive fast |
