Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 10-12-2005, 08:36 AM
naif0391 naif0391 is offline
problem with 97 gp, mass air flow??
ive been experiencing a problem with my 97 grand prix for a little while now, my check engine light seems to go on and off many times a day, and then when i turn on my a/c or heat, my intake starts sucking in air like theres no tommorow, my car shakes a bit and my rpm's go up and down. Anyone heard of this or know how i can fix this problem? thanks
Old 10-12-2005, 09:30 AM
maxwedge maxwedge is offline
A990 racer
Re: problem with 97 gp, mass air flow??
Get it scanned post back the codes, eliminates guess work
Old 10-12-2005, 11:38 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Re: problem with 97 gp, mass air flow??
I agree that if you have a persistent SES/CEL light get it scanned.
What makes you believe that you have a mass airflow problem?
Any component on the throttle body such as the MAF sensor, idle air controller (IAC), throttle position sensor (TPS) or vacuum leak can give you those symptoms. For example: A defective, shorted or open IAC will cause the rpms to be very erratic. However, normally the idle goes to over 1000 rpms or more and stays there. Plus it will make your engine sound like it has a vacuum leak and it will make weird noises. The positive crankcase vent. system goes to pot as a result.
Thrasher CAI, DHP v1.0 PCM, SLP Headers,
3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 72mm TB,
TB spacer, MSD 8.5mm wires, Autolite 103,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
1/4 ET: 13.210 sec. @ 104.490 mph
0 - 60 ft: 1.945 sec.
Timeslip 08/12/06
AF Community Guidelines
Old 10-12-2005, 01:06 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Auto Zone and Advance auto now scan for free, so you won't have to pay $40-$60 at a shop.
Old 10-12-2005, 08:03 PM
scanned it and came up with MAF or VAF circuit low input, p0102
Old 10-13-2005, 06:19 AM
BNaylor's Avatar
To troubleshoot it further, all you have to do is disconnect it. Undo the electrical connector to the MAF. Test the car and see what it does. With no MAF input detected, the PCM will use programmed air flow values. If driveability returns get a new MAF sensor. With MAF undone, the initial idle will be a little erratic until the engine warms up but it should be driveable. Good luck!
Timeslip 08/12/06
Old 12-26-2006, 10:26 PM
Dornracing Dornracing is offline
YEAH!!!! I have the same code and issue in my 96 corisca 3400sfi... and i did the test and it ran perfect!! It was dputtering and dieing before and then when i unplugged it.. it didnt at all!! I wil be getting a new MAF i guess!
Rhues Page Link
Old 12-27-2006, 07:19 AM
A990 racer
Just so you know this thread is over a year old, dead now.
Closed Thread
