| Graphic Manipulation Post and discuss different automotive art works- photoshopped, 3d graphics, and hand-drawn. |
: ( changing rims
I have see the site of mentel but it lack of explanation on how to change rims and colors(or I just dont understand)
okay what you do is this.
1. find picture of a rim that is at the same angle as the picture your putting them on. 2. using the Polygonal Lasso tool (it's in the top left part of the tool bar, it's 2nd one on the left from the top) cut around the rim, press CRTL+C to copy the rim , and then go to ur picture and press CRTL+V to paste it on there. ![]() 3. Place the rim right overtop your picture'. press CRTL+T to free transform it. Zoom in a bit to get a better look at it , then right click on the rim that u cut out and select "DISTORT". ![]() 4. Pull the rim to the shape you want it. match it to the rims size on the picture. ![]() 5. once your done re-sizing the rim, hit ENTEr to get out of free transform and take a look at your picture. there, hope th is helps you!! now all that's left is the back wheel, try it out!......... Try taking the front wheel off that picture above , and putting it on the back wheel!........good luck! -mentel |
The easiest way i can tell you to change rims is this.
Find the photo you want to TAKE the rims from, select the rims. Use the polygon lasso tool, (if you need help, use help and search select). Once you have selected the rims, go edit,copy. Now go too the photo you want to put them on, and go edit, paste. They will probably be the wrong size or look wrong. So go edit, transform. Use all the different kinds of transforming to get them to look right. sarujin
Real Car: 1990 Honda Civic Hatch R/C Cars: M-01, M-03, Pro3 & Xpress |
dont use distort use free transform...make it the right size....then rotate it for the right angle.
hey intgra, how about let him use whatever he's most comfortable with.........they both perform the same task
Hey mentel, intgra22 was just giving him another way of doing something, why take offence?
Hell you were telling him to use distort, not anything else. sarujin
I have found how to do it
