Go Back   Automotive Forums Car Chat > Racing > Technical
Technical Discuss different strategies and theories of the racing aspect.
Old 10-08-2005, 07:17 AM
dnrnflcpl469's Avatar
dnrnflcpl469 dnrnflcpl469 is offline
Send a message via Yahoo to dnrnflcpl469
eng rebuild RWHP
Hey hello everyone i have BB Chevy 454 and want to add a new cam, lifters,rockers a set good for at least 7000 rpm plus. also while im tearing things apart what can i do to develop some great RWHP.
any and all advise appreciated thanks one and all Dan
Dan & Robin Ricochet Anger Management: The need for speed!
Old 10-08-2005, 01:31 PM
dimefury's Avatar
dimefury dimefury is offline
I'm not well versed in chevy engines, but the following tricks can be done with any motor to increase RPM and power........
-weigh all moving parts and remove some material (through mild grinding) to get all like parts identical in weight (rods, rockers, etc.) then polish them
-get forged pistons
-if available, get a fully counterbalanced crank, then knife edge it
-have the block gone over by a machine shop, bore, deck (will give you a slightly higher comp. ratio)
-replace all belt driven accessories with electric units (fuel/water pumps, etc.)
....just a couple ideas off the top of my head.....chevy guys could probably help more....
Old 10-08-2005, 04:45 PM
-The Stig-'s Avatar
-The Stig- -The Stig- is offline
On Fire!
Send a message via AIM to -The Stig-
Re: eng rebuild RWHP
add some form of forced induction: Supercharger, Turbo or Nitrous.
Those always help. hehe.
2003 Chevy 1500HD - Hauler
1971 Chevy Camaro RS - Track Car
User Guidelines It's important to read, like the Bible. But unlike the Bible we will strike you down if you jerk off around here.
Old 10-08-2005, 06:17 PM
Andydg Andydg is offline
Cam and heads always help. I'm not sure how far you're tearing the engine down but you could get a stroker kit for it too.
Old 10-17-2005, 05:39 PM
MrPbody MrPbody is offline
AF -Advisor
To rev a 454 up there, you must have a forged steel crankshaft. We've seen MANY failures of cast cranks (iron AND steel). Due to the long strokes used in these engines, harmonics are a bitch. As another said, have it internally balanced, lighten it up, use only GOOD parts, etc.
We usually use Dart heads for race BBCs. Some customers opt for iron. Heavy stuff. We've also installed a couple pair of the "Jeg's" BBC aluminum heads. Not bad for the money! Not Darts, though.
You'll need at least a flat tappet solid lifter cam, and probably a solid roller would be the better choice.
What kind of vehicle are you installing this in? What is the origin of the engine(car or truck)? What are your fuel requirements (octane)?
All this is doable. You must establish a budget (being certain it's realistic). Then prioritize the steps. You will certainly need the assistance of a high quality machine shop (automotive).
Boring, balancing, good head work, right cam choice, are all part of the package. Tell me as closely as you can, what exactly your performance goals/needs are, and I can put together a suggested package for you.
Jim
Old 04-26-2006, 10:20 PM
boarder_punk's Avatar
boarder_punk boarder_punk is offline
Send a message via MSN to boarder_punk
DO NOT stroke it if you want high rpms. This will just make it more difficult for the reciprocating assembly (pistons, conrods) to change direction at the end of each stroke. It would actually help with rpms to DE-stroke it.
You will need the best of everthing when it comes to your valvetrain; maybe see what Jesel Valvetrain Innovation (www.jeselonline.com) has to offer for your application. Or you could try Coates International Ltd. (www.coatesengine.com/technology.html). They offer a very innovative camshaft design that will handle extremely high rpms.
Old 05-09-2006, 08:09 AM
AF -Advisor
Borderjunk is correct. Stroking it will pull the power band "down". We seldom see any BBCs with the 4" or longer strokes revving higher than 6,500, except in all-out racing applications.
We have one 427 (bored .100" to 447 CID) that turns on the shift light at 8,000 and bumps the chip at 8,400. Just over 800 horsepower. NOT a "street" engine. The shorter stroke makes the revs livable.
Still waiting for a more definitive answer to the application.
Jim
