Old 10-06-2005, 08:27 PM
98gpking 98gpking is offline
Send a message via MSN to 98gpking
s/c pulley leak
the other day i had my car parked on the side of the road. i noticed the smell of supercharger fluid and i opened the hood. it was leaking right out of the end where the bolt is that holds the pulley on. my guess is that the coupler is bad. its making the ticking noise like it is bad. i was just curious if the coupler was the seal for it. or if there is a different seprate seal.
also i was told that at colder temperatures the gtp actualy has about 2-3 lbs more of boost. if i was to tell someone how much boost i have what would i tell them. i only have these mods done. 8mm spark plug wires, K&N intake.
Old 10-06-2005, 08:33 PM
Ripn12s's Avatar
Ripn12s Ripn12s is offline
Send a message via AIM to Ripn12s
Re: s/c pulley leak
Stock GTP i would say 7-8 lbs of boost
The coupler attaches the snouts drive to the gears for the rotors in the case. On my zzp modular pulley system they give you a black push cap for the snout. Doesnt even use a screw.
GTP's def like the cold weather. My car ran 12.9's in 60deg weather in IL and 13.2's in 100+ deg weather in TX
Same mods different weather.
Old 10-11-2005, 09:45 PM
regalfriend regalfriend is offline
Re: s/c pulley leak
In New York where i live , it can go from 0 to 100 deg in 1 year....i guess the benefit of colder air is more compressed air with the S/C..approx what temp does an intercooler chill the air?...are there any benefits using it on a 10 deg day?
Old 10-12-2005, 09:14 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: s/c pulley leak
You need a new snout seal to take care of the leak. Snout rebuild kits are available for around $20.
Thrasher CAI, DHP v1.0 PCM, SLP Headers,
3.25 SC pulley, CAIT GMAF, 2.5 DP/Hi-Flow CAT,
u-bend delete, 160 TS, ZZP Stage 1 72mm TB,
TB spacer, MSD 8.5mm wires, Autolite 103,
Goodyear Gatorback Serp. & SC Belt,
Nitto NT555R Drag Radials
1/4 ET: 13.210 sec. @ 104.490 mph
0 - 60 ft: 1.945 sec.
Timeslip 08/12/06
AF Community Guidelines
