Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 10-05-2005, 05:30 PM
master2090 master2090 is offline
i need help
i have a 1984 monte carlo with a 229 v6 in it. i believe the front seal is leaking and i wanted to know what i need to do to replace it(like taking out the engine or not) and whatwould it cost to replace it. also what i would need to do to replace the rear seal just in case thats going bad to,and how much would that be. please someone help me out here
Old 10-05-2005, 09:54 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Re: i need help
If you plan on doing the work yourself, your best bet is to purchase a Haynes or Chilton manual. These books explain in detail how to disassemble and reassemble parts of your engine, info on brakes, tuneups, has all your specifications, and just about all the info you would need to work on your vehicle. The parts are easily found at your local auto parts store, and are relatively inexpensive. You also may be able to research replacing the front and rear seals on your engine online, but your best bet would be to have one of the repair manuals I previously mentioned. If you decide to have a garage do the work, it would also be wise to get more than one estimate to do the work.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
