Old 10-04-2005, 08:23 PM
transgta transgta is offline
Talking finally got a transmission code
My 01' supercrew 5.4 code is p1780 transctrl sw circuit out of range.
Ok, does this mean any thing to anybody? Shifting funny. HELP ME!
Old 10-05-2005, 05:59 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: finally got a transmission code
That deals with the OD button. It indicates a broken wire or a short to ground. If all wres are good, suspect the PCM.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 10-05-2005, 07:23 PM
thank you .. but whats a PCM?
Old 10-06-2005, 09:54 AM
way2old's Avatar
TOKEN HILLBILLY
Powertrain Control Module. Computer
Old 10-06-2005, 09:30 PM
The guy that rebuilt my tranny says i need the neutral switch that bolts on the side with an elec plug and attaches to the slide lever. He says that tells computer how to shift. What this thing does is when it shifts it takes a second to shift and then you feel it go in gear. Any output on that before i buy the part. Thanx
Old 10-09-2005, 05:32 PM
way2old's Avatar
TOKEN HILLBILLY
That part is a good possibility. However, you can install it yourself. There are lines on the switch that need to line up when it is installed with shifter in neutral. Not a hard job.
