Go Back   Automotive Forums Car Chat > Buick > Century
Old 10-02-2005, 01:28 PM
AJB123 AJB123 is offline
3.3l engine bogs down when it is put in drive
It is a 1992 Buick century with a 3.3L V-6. When the car idles it has a small miss in it. When you put it in drive the engine bogs down and starts to putter untill you give it gas. Does anyone know what the problem could be. Let me know. Thanx Aaron
Old 10-05-2005, 09:07 AM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Re: 3.3l engine bogs down when it is put in drive
Have you checked your spark plugs, plug wires, etc.. recently? Also it could be an injector going bad, do you have anything to test injectors?
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 10-07-2005, 03:52 PM
Hi Josh. The plugs and wires are new. I double checked the spark plug gap its ok. I have a code 42 from the check engine light. That is the eletronic spark timeing circuit. It consists of ecm, crank and cam sensor, coil pack, mass air sensor. I am going to have another look at it this saturday. Thanx for the help. If you have any more ideas please let me know Thanx Aaron
Old 10-08-2005, 07:55 PM
-Josh-'s Avatar
Nothing much i can really add, just be sure to post exactly what was wrong with it when you get back in case future members have the same problem.
AF User Guidelines
Old 11-23-2005, 10:01 PM
It turned out to be the ignition control module. Thanx
