Old 09-29-2005, 06:09 PM
newifestud newifestud is offline
Lightbulb clutch/tranny problems???
i have a 2001 suzuki vitara with manual trannie. up until yesterday i have had no problems with it. but yesterday i went to a friends house drove there perfect and when i decided to leave i started my vehicle in neutral and tried to put it into gear no luck. the only way it would go in gear was if it was started in gear but then u could not change the gear it would only go into neutral i was wunderin if anyone knew what was wrong and how to fix it. thanks
Old 09-29-2005, 07:47 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: clutch/tranny problems???
It's good to see someone from the rock is here.
I think your clutch is not disengaging. Does your clutch pedal feel the same or has it gone mushy?
Likely you have a hydraulic clutch, and you have lost some or all the fluid. Check the clutch master cylinder fluid level. It should be on the firewall beside the brake master cylinder, (it looks similar but smaller)
Old 09-30-2005, 11:24 AM
yes it is a hydralic clutch and i've already checked all the levels. the clutch donmt feel the same it has lost all presure. i was thinkin the was maybe air in the lines. a couple of friends also told me that it may be the same problem. do u think bleeding the clutch would fix the trouble??
Old 09-30-2005, 11:50 PM
MagicRat's Avatar
Bleeding the lines cannot hurt, but generally, unless you deliberatly drain fluid, the only way air can get into the system is if some part has failed and allowed fluid to leak out.
If there are no leaks and no air in the line, the master cylinder may have failed or the clutch fork has failed.
Old 10-01-2005, 11:41 AM
there are no leaks or breaks in the line that i can see. i tried bleeding the clutch but it did no good. my next attempt will be to try and get a licenced mechanic to look at it and give me his opinion upon it. that is probably the best route for me to go now. thanks for all the help. if u think of anything i should know just post a reply i will still keep checkin to see if anyone has an opinion they need to share on the deal.
Old 10-02-2005, 06:50 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
MagicRat hit it on the head. Either the clutch master cylinder or slave cylinder is bad. Just like a brake master cylinder, when the inside seals wear out, they let fluid squeeze by and therefore don't properly operate the clutch. There doesn't have to be an external leak, its just leaking past itself internally.
Dragging people kicking and screaming into the enlightenment.
