Old 09-25-2005, 11:37 PM
D_LaMz's Avatar
D_LaMz D_LaMz is offline
Question How would I cut this!!
Ok, so I dont go back to school until Wednesday because of Hurricane Rita. I'm back to doing this hood for my Supra and it will be the TopSecret hood. Then I will cast some of the hoods for later use or maybe even selling them! So I need a way to cut this, FOTW's tutorial will not work because his were just panel lines.
Pics:
Blue will mark where I will cut.
Tools that I have:
Knife blades and a Panel Scriber
Scissors, metal/plastic scissors, hobby knife and file with a pointy end.
Small hacksaw?
So......anyone got ideas on how I'm supposed to cut this?
THANKS
Old 09-26-2005, 12:10 AM
malsheem's Avatar
malsheem malsheem is offline
20 inches and growing ...
Use a scriber to make your own panel lines on those blue lines in your pic. Go slowly, especially on the curves, (use a ruler or tape some thin styrene along the straight lines to keep it straight) until you have a panel line. Then follow Fly's tutorial. Also, it might be a good idea to invest in some P/E saws. Makes cutting very easy.
-Joe
www.quietrage.com
CWest R34 Skyline GT-R
Old 09-26-2005, 01:17 AM
D_LaMz's Avatar
Re: How would I cut this!!
Thanks for the idea, does Hobby Island have any PE saws?
Old 09-26-2005, 02:07 AM
malsheem's Avatar
Re: Re: How would I cut this!!
Yup, that's where I bought my set.
-Joe
www.quietrage.com
Old 09-26-2005, 10:12 AM
Zlaja_'s Avatar
Zlaja_ Zlaja_ is offline
Send a message via MSN to Zlaja_
what could work is if you mask it off so you have guidelines where you want to cut, then heat up a sharp blade enough so it melts plastic, cut panel lines with the heated blade then use the scriber.
Old 09-26-2005, 10:27 AM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
I built a hood like that a while back. I used the back of my Xacto to cut out the rectangle. So I had to big holes in the hood. Using the back of an Xacto blade is like scribing, just keep going over and over. Its slow but works well. Then I sanded the edges smooth. After that I cut out pieces of styrene for the louvers. I hope this helps!
-Mike
Old 09-26-2005, 11:31 AM
Vric's Avatar
Vric Vric is offline
I would go this way. and work slowly.
The longer you work, the cleaner the cut will be.
Old 09-26-2005, 01:36 PM
ouizel's Avatar
ouizel ouizel is offline
For this type of job I've found Dymo tape (you know, for the label makers that produced raised letters) is the perfect guide. Cut it to size and apply it and then you can scribe along the line without fear of the blade slipping and ruining the surrounding area. And since the tape is fairly flexible it handles compound curves. You can find it at office supply places for a $2-3 a roll.
Old 09-26-2005, 02:44 PM
klutz_100's Avatar
I agree. Dymo tape is a great guide for making/scribing new lines. Also as said, PE saws (Hesegawa set for example) are very useful, precise and past a long time so thay are a good investment.
Old 09-26-2005, 09:06 PM
D_LaMz's Avatar
Thanks for the tips! Sadly Hobby Island is closed until Thursday.
One more question though, can I sand 90 second epoxy?
Old 09-26-2005, 10:37 PM
klutz_100's Avatar
IMO yes - once it has set up fully. It will have a different property to the surrounding styrene though, so it will sand away at a different rate/speed,
