Old 09-20-2005, 09:43 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Fuel Filter Change
Hey all;
Decided I should change the fuel filter. Never done it, and dont know when it was done. Question: Where is it? Is it in the backseat? I lost my Haynes Book. Thanks.
Oh, and is it hard?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 09-20-2005, 09:57 AM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Re: Fuel Filter Change
Under the battery and intake pipe on your car. According to all data anyway.
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 09-20-2005, 10:42 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: Re: Fuel Filter Change
Don't you mean "SomeData".
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 09-20-2005, 10:48 AM
-Josh-'s Avatar
Re: Re: Re: Fuel Filter Change
Oh i could go on for days about that....apparently the firing order on a GM 5.7 is 1-2-3-4-5-6-7-8..... Not exactly the greatest technical program, good diagrams though.
AF User Guidelines
Old 09-20-2005, 11:11 AM
david-b's Avatar
Dave is THAT guy
I shouldve searched before posting. Found it within 2 seconds. Duhh. How epensive are fuel filters, and can I get one at AutoZone? Also, do I have to relieve the fuel pressure beofre doing? Thanks
75 Monte Carlo
Old 09-20-2005, 11:25 AM
Benag Benag is offline
Fuel filters are about $20 at autozone. You might want to relieve the pressure to prevent a lot of gas pouring out of the fuel lines but you could always just get a cup or bucket to catch it in. If you go by the book you have to have a fire extinguisher handy too. Changing the filter is actually pretty fun and if it is bad you will notice a great change in your car's performance.
'95 Eclipse GS-T
5-Speed
Boost, air/fuel gauge.
Old 09-20-2005, 11:28 AM
david-b's Avatar
Dave is THAT guy
Is alot of fuel going to pour out? I would imagine because of the fact that the car is not on, that it would just be whats sitting in the lines. Is that alot? Fire extinguisher myass. Although it would have been nice when my car caught fire when I first bought it.
How would I relieve the pressure? Then, how would I get the pressure back? Thanks
75 Monte Carlo
Old 09-20-2005, 11:51 AM
-Josh-'s Avatar
Remove the fuel pump relay, and depressurize the fuel rail, that should take care of it. Once you put the relay back on and cycle the key it will pressurize again.
AF User Guidelines
Old 09-20-2005, 03:56 PM
david-b's Avatar
Dave is THAT guy
How do you depressurize the fuel rail? I know this is probably basic knowledge, but I've never done it. It would also be good for people who search on this in the future. Thanks
75 Monte Carlo
Old 09-20-2005, 04:59 PM
SLoe's Avatar
SLoe SLoe is offline
Disconnect the fuel pump electrical connector.
Start the engine and let it run out of fuel.
Turn it over to make sure it does not start.
Done
96 GST 5 spd.......(R.I.P.) smashed by a fallen tree
2001 Camaro SS 6 speed goodness!
Old 09-20-2005, 05:03 PM
david-b's Avatar
Dave is THAT guy
Wouldnt letting the car run out of fuel cause it to possible mis-fire?
And that will run the lines dry? Then disconnect everything I need to and Im ready to go?
75 Monte Carlo
Old 09-20-2005, 05:08 PM
SLoe's Avatar
It will only take a few seconds. You aren't going racing ; )
Old 09-20-2005, 05:10 PM
SLoe's Avatar
There will still be a little bit of fuel leakage, but you won't get sprayed in the face this way.
Old 09-21-2005, 10:21 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Just let the gas leak a little bit it's not much and it's gonna leak a little no matter what so why go through the touble? You might want to get a 14mm flare wrench for the bottom bolt.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 09-21-2005, 12:29 PM
You know I've done this a few times and the manual says that your car will die but I have let mine run for like ten minutes and it never died. I still didn't have a lot of spillage anyway.
'95 Eclipse GS-T
5-Speed
