Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 09-20-2005, 09:00 AM
roman35 roman35 is offline
Question Change engine oil message
Change engine oil message appeared. Have changed oil, but message still come on. How to reset? We do not have an owners manual, so we cannot reference that.
Old 09-20-2005, 09:31 AM
cdru's Avatar
cdru cdru is offline
Re: Change engine oil message
Check your owners manual. It usually is reset by holding in a button for a certain period of time if it's like other vehicles.
Vinyl adds horsepower, right?
Old 09-20-2005, 12:31 PM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
On some Chevrolets you reset this message by turning the ignition switch to the run position with the engine off. Fully press and release the accelerator pedal three times within five seconds. The CHANGE ENGINE OIL indicator will flash for five seconds to notify the driver the system has been reset. On some models there may be a reset switch on the fuse panel.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
Old 09-21-2005, 06:50 PM
RNRea RNRea is offline
On mine (2004), I cycled through the trip meter readings (Trip-A, Trip-B, Oil) until I got to "oil" which was at zero. I held the button in for about 10 seconds, until it reset back to 100. The reset time is longer than the trip readings, so you don't accidentally reset the oil minder instead of trip miles.
Old 09-21-2005, 09:34 PM
Glen_T Glen_T is offline
If you check GM's TechLink, it lists the oil life monitor reset procedures in some of the archived issues....lots of other good info in there as well....
http://service.gm.com/gmtechlink/ima...3e.html#story9
