Go Back   Automotive Forums .com Car Chat > Engineering/Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 09-17-2005, 02:36 AM   #1
flip888
List of Cars that Take Well to Forced Induction
I was wondering if there are any lists of inexpensive N/A cars that would make good project cars to add a turbo or SC to that would have a lot of potential for being fast, or if you guys would help make one.
The cars im thinking of would not require any engine swaps, wouldnt need aftermarket rods/pistons, and would be under $10,000.
The cars i came up with through searching were
1st-gen Dodge Neon
integra LS or GSR
LT1 z28 camaro
and the 5.0 Mustang
flip888 is offline   Reply With Quote
Old 09-17-2005, 01:56 PM   #2
Schister66
AF -Advisor
Schister66's Avatar
Send a message via AIM to Schister66 Send a message via MSN to Schister66
Re: List of Cars that Take Well to Forced Induction
GSR would be my pick, but that's because i have one! I think that if you're going to boost...you should go DSM or Honda.
2015 DGM STi - 2006 SGM STi - 1999 Built/boosted GSR
Schister66 is offline   Reply With Quote
Old 09-17-2005, 04:20 PM   #3
Hit_N_Run-player
Send a message via AIM to Hit_N_Run-player
doesnt the GSR have a 10.6/1 compression ratio? I wouldnt see that as one of the top choices for taking well to turbocharging. If i was gonna add to the list i would say a 240sx with a KA24DE because of the large amount of people turboing these cars and having them do well on the track and streetability. Plus the amount of aftermarket support is greatly increasing.
1988 conquest TSI
-Lots of mods, finally finished WOOT!!
Horsepower sells cars,
Torque wins races!
Hit_N_Run-player is offline   Reply With Quote
Old 09-17-2005, 04:23 PM   #4
Zachp911
Zachp911's Avatar
Re: Re: List of Cars that Take Well to Forced Induction
Hondas arent the best cars to turbocharge because of there high compression ratio. If you want a car that will respond good to turbo, go with Nissan or something.
2008 BMW 335i
Zachp911 is offline   Reply With Quote
Old 09-17-2005, 04:39 PM   #5
CBFryman
Banned
CBFryman's Avatar
Send a message via AIM to CBFryman Send a message via Yahoo to CBFryman
When looking for cars that will take well to it look at stock AF ratio's and compression ratio's...if they are ran rich stock the extra airwill help lean them out, making them take even better to FI. also the compression ratio should be looked at if you plan on running any more than 6-8psi...which is all you would want to run on a stock honda motor...
also look at transmission problems in consumer reports, tranny's going bad with no performance nodifications sure wont hold up to the 50% or more increase in power and torque.
Also cars that have boosted counterparts and use the same block and heads will usually take well to turbocharging, especailly if the ECU is programmed after boost is added.
for the factor of ease and cost V6's and V8's should be avoided when talking turbo unless you WANT to do a twin set up.
CBFryman is offline   Reply With Quote
Old 09-17-2005, 05:01 PM   #6
curtis73
Professional Ninja Killer
curtis73's Avatar
The LT1 will do well, but they have a stock compression ratio of 10.56:1. A wider LSA cam with a bit more duration might bleed of some cylinder pressure allowing you to run some more boost, but in stock form, 3-6 is about all you can do with pump gas. To be done right I might consider extra thick head gaskets. You could also polish the chambers to add a few cc's and remove hot spots, and/or do a heavy valve job to get a couple cc's. Then you could get in the 6-8 range pretty easily.
But, saying which ones take to turbos is kinda like asking which cars look best with body kits? I suppose the answer is any of them if done right. If you're going to go to the trouble of fabricating exhaust, intake tubing, intercoolers, and designing the whole system, a head swap or cam swap is the easy part.
I think many of the mid 80's RWD cars are perfect candidates. Find yourself an 87 Cutlass with a 307. They had anemic 7.8:1 compression, but are built with the same strong V8 guts as their muscle car predecessors. Those same rods used to support 350+ hp. With some main studs, rod studs, and head studs (swap to 5A heads), you'll be capable of supporting at least 400 horses. Although blow-through carbs are not ideal, they can be tuned to run just fine. You can avoid the (minor) headache of tuning or adding EFI.
Dragging people kicking and screaming into the enlightenment.
curtis73 is offline   Reply With Quote
Old 09-18-2005, 10:23 AM   #7
Mr. Luos
Firebird Guy
Mr. Luos's Avatar
Boost an LS1. 500+ RWHP with a couple bolt-ons and a supercharger.
Only takes about 7 PSI to get that as well.
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Mr. Luos is offline   Reply With Quote
Old 09-18-2005, 01:58 PM   #8
Schister66
AF -Advisor
Schister66's Avatar
My GSR...as with all USDM GSR's only have a 10.2:1 cr. The JDM GSR's have the 10.6:1 cr.
I think a Nissan would be a good car to turbo... i would really like a 240sx or a 300ZX, but there are also a lot of parts available for Hondas and Acuras.
Plus the higher cr helps with the loss of low end power in turbo applications. It just takes a little better tuning to keep them together in the long run.
Old 09-18-2005, 02:22 PM   #9
ec437
ec437's Avatar
Alot of people turbo BMW e30's.
SoStAsSaId: and the flight attendant is cute... if i was a lesbian, i'd join the mile high club
<---call this number
ec437 is offline   Reply With Quote
Old 09-22-2005, 03:06 PM   #10
beyondloadedSE
AF Ford Contour-Advisor
beyondloadedSE's Avatar
Nissan Maxima. 95-99. That motor is awesome! My friend turboed his as well as on the bottle. Made 538 whp, 603 wtq. This was on a completely stock bottom end. Only things he upgraded was the clutch, intake manifold, and fuel injectors. Axles, differential, heads, etc were all left untouched. Axles and differential both held up to slicks as well.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
beyondloadedSE is offline   Reply With Quote
Old 09-28-2005, 07:05 PM   #11
2.2 Straight six
That thing got a Hemi?
2.2 Straight six's Avatar
Send a message via AIM to 2.2 Straight six Send a message via MSN to 2.2 Straight six
this depends on whether you're talking about with minimal work. any engine can be tuned, it takes time money etc.. like curtis said. you can take a 10.6:1 ratio engine an by changin' lots of things totally transform it. e.g. low compression pistons, lightened an balanced crank, new con rods (possibly long stroke) you can either bore the engine out, or fit re-enforced cylinder liners for boost, port+polish, valves, cams, somehow change from carb. to injection (im sure it is possible) and other work too.
a good example is the brabham bmw powered F1 cars of the eighties: they use 2litre engine blocks from road E30 M3s, with at least 100,000miles/kilometres (not sure which) they used re-enforced cylinder liners for the boost, had a turbo off a truck, with lots of internal work and an intercooler the size of a house-hold radiator (like 80x140cm i think) they managed over 1,400bhp. it was more, but BMWs dyno only read up to 1,400bhp. an the figures were recorded with massive amounts of tye slip.
Seatbelts Saved My Life
2.2 Straight six is offline   Reply With Quote
Old 09-28-2005, 10:42 PM   #12
Hit_N_Run-player
yeah, the carb to fuel injection is a popular thing to do, ive seen many older hotrod v8's swapped over to FI.
1988 conquest TSI
Torque wins races!
Old 09-29-2005, 02:17 AM   #13
2.2 Straight six
oooh...thanks, i was sure its possible but had little or no recolection of seeing it done. thanks for that though.
Old 09-30-2005, 11:25 AM   #14
Polygon
The Red Baron
Polygon's Avatar
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
10.2:1 and 10.6:1 aren't a whole hell of a lot different. However, both are too high to turbo-charge on pump gas IMO. If you want to keep that CR that high on the street you're asking for trouble. You can't run a lot of boost and I don't care how good your tuning is it won't save you from a bad batch of fuel or detonation at full boost. You'll be the owner of some new ashtrays. Hell, you could even throw a rod through your block.
Unless you plan on runing very low amounts of boost you're going to have to get lower compression pistons, some stronger rods, and you will have to sleeve that block. Not what I call a good engine to turbo-charge.
Besides most of the engines metioned any car with the Chrysler common block is easy and inexpensive to turbo-charge. Plus, the blocks and internals are rock solid.
Polygon is offline   Reply With Quote
Old 09-30-2005, 08:03 PM   #15
2.2 Straight six
when turbo charging, would you use a long or short stroke kit ? because i think the long stroke kit would give you better torque, yet the short stroke kit would allow higher capacity, is this right or have i missed something ?
