Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > General
General news, articles, other.
Old 05-10-2002, 05:21 PM
Domiken's Avatar
Domiken Domiken is offline
Send a message via AIM to Domiken
Full Throttle!
I unfortunately have an automatic G20 P11, and ive noticed that under the gas pedal there is a little plastic black thing that doesnt let the pedal go all the way down. If i remove that will my car redline everytime i put the pedal to the metal or it wont dont anything. FEEDBACK!!:smoker2:
Only the good die young!!
Old 05-10-2002, 08:46 PM
kris's Avatar
kris kris is offline
Off playing with fire.
Re: Full Throttle!
It will not make you redline.
Old 05-10-2002, 10:21 PM
NismoPC's Avatar
NismoPC NismoPC is offline
Re: Full Throttle!
Brandon
'96 G20 - modified
Old 05-12-2002, 08:46 AM
Domiken's Avatar
Just curious.
Old 05-13-2002, 10:33 AM
RCer's Avatar
RCer RCer is offline
Redline limitation is governed by the ECU, not by the length of the wire or the displacement of the pedal.
Want to go redline? You will have to find the way modifying the ECU. I think not Jim Wolf have been 100% sucessfull doing this!
Americo
2000 Primera.
Old 05-19-2002, 06:03 PM
AWD Primera's Avatar
AWD Primera AWD Primera is offline
Dude, your throttle cable only wants to open the butterfly valve thing in the Plenum chamber 90 degrees. Removing the plastic thing will only mean you can push the pedal further, hence pulling more throttle cable and opening the butterfly valve past 90 degrees. 90 degrees is optimum, if it starts to go any further it starts closing the throttle because it turns full circle - not good. Anyway, they should be a stopper on your throttle cable so that it opens to optimum and no further (90 degrees).
Battery Light when Full Throttle ??? dink182 Taurus | Taurus Wagon 10 03-05-2004 12:09 PM
Help! My CRX Hesitates in full throttle! quiXilver '88 - '91 Civic | CRX | Wagon | Shuttlee 10 11-22-2003 05:42 PM
Full Throttle Forum NISSANSPDR Cars in General 1 09-11-2002 02:16 PM
