Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 09-08-2005, 09:11 AM
bs4u00 bs4u00 is offline
Fuel filter location on '00 4Runner
Hi, new to the site, so I'm sure this question has been asked previously.
But I need to change the fuel filter on my 2000 4Runner. Can someone tell me where its located? I looked in the usual passenger side location, with no luck. Anything special I need to do when replacing it?
And the fuel filter I bought has no bracket like some I've seen on the internet. Do I need one with the bracket or without?
Thanks in advace for any help.
Old 09-08-2005, 02:37 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Fuel filter location on '00 4Runner
Under the driver door, behind a fiberglass shield by the frame rail. Not sure about the bracket.
Take off the shield and unbolt the bracket holding the filter, from the chassis. if the bracket can be removed from the filter (if it's movable), then you don't need a bracket.
Be sure you actually need a filter. Normally, they don't need to be changed. Check the discussion on fuel filter replacment in the Camry FAQ thread for general hints and cautions.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 09-12-2005, 11:54 AM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Be sure to depressurize the fuel line before changing the filter.!!
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
Old 09-14-2005, 07:41 AM
Thanks for the replies. I changed the fuel filter last weekend.
The fiberglass shield was fastened to the vehicle with 3 bolts(soft steel!). One of them rounded off and I could not get it off. So I had to change the filter with it left on.
The filter came off and went back on pretty easy. Probably only 1/2 or 3/4 cup of gas came out, so that was nice. Not too messy considering the shield was still on.
Then I had to put the bolt back in the filter clamp. I couldn't get it back in because the bolt is too short. So I went and got a longer bolt and that worked much better.
