Old 09-06-2005, 06:31 AM
cavasinj cavasinj is offline
trac off issue
Hey all- i have replaced both my front wheel bearing assemblies already as they both went bad. Now my problem is that the trac off light i son all the time, as is the abs light. So, as I didn't like the traction system when it was operating correctly, I am curious if there is a way to simply disable the trac system, without affecting abs or if these both turn off as a "precaution" . Also, as both of the back hubs/bearings are fine, then why the hell other than a bad sensor would this happen, and of course are the computer diagnostics good enough to detect just a bad sensor?
Thanks all
joe
Old 09-07-2005, 06:23 AM
anyone awake yet?
Old 09-08-2005, 06:09 PM
kraziqtashes kraziqtashes is offline
Re: trac off issue
I'm having a similar problem I believe. My Trac Off and Anti Lock lights come on at the exact same time. I'm hoping someone responds to this as I am curious about what it is.
Old 09-08-2005, 07:26 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Re: trac off issue
Computer diagnostics are good enough to detect ABS DTC error codes, however, you're probably limited to a dealer that has a Tech II machine. A TII will read GM manufacturer specific chassis codes in which ABS is part of.
Some high end hand held scanners can also read GM ABS cdes.
Timeslip 08/12/06
AF Community Guidelines
Old 09-09-2005, 07:21 AM
Talking trac off issue
bnaylor- I know what ABS is, but what do you mean by an ABS DTC code? never heard that before...
Last night I even tried unplugging and cleaning both front connections to the sensors, and nothing, so I assume that a sensor is bad.
Thanks
Old 09-09-2005, 08:06 AM
BNaylor's Avatar
Re: trac off issue
Thanks
DTC is short for Diagnostic Trouble Code. Did you say you replaced the front wheel hub/bearing assembly earlier? What brand replacement did you use?
Timeslip 08/12/06
Old 09-09-2005, 09:26 AM
Yep. Replaced both hubs, as they went bad about 1 year after I bought the 'beauty'. Brand though, not recalling, replaced them about april/may of this year. All I can recall off the top of my head is that they have a lifetime warranrty, whatever that means. I can, however tell you that I bought them at Murrays, if thats any help.
Old 09-17-2005, 01:43 AM
ddavis ddavis is offline
Re: trac off issue
anyone awake yet?
I am new at this, but my trac light jumps on all the time and then it is very hard to drive it's almost like the transmission is going out
Old 09-17-2005, 09:45 AM
BNaylor's Avatar
Probably a bad wheel sensor which is located in the hub/wheel bearing assembly.
Timeslip 08/12/06
Old 09-17-2005, 04:51 PM
vamc's Avatar
vamc vamc is offline
Re: trac off issue
bnaylor3400- i agree with you on this one. I dont have a better answer.
Old 09-18-2005, 04:31 PM
glad you replied back to me, the problem with the trac is worst by the day. I'll have someone take a look for me. Thanks
Old 09-19-2005, 02:46 PM
kernalklink kernalklink is offline
before having someone look at it check your air intake sensor, i was having the same problem and it was that i accidentally unplugged the air intake sensor when tuning up. it was shifting so hard that i thought the tranny was going out i took the car into Tuffy and had it hooked up to their computer. all they did was reconnect my air intake sensor and viola it runs beautifully again!
Old 09-19-2005, 04:22 PM
Re: trac off issue
Thanks, I'm going to check it out now, will let you know what happens
Old 10-19-2005, 01:38 PM
DTC's
Hey all- recently had my damn service vehicle soon, brake, anti lock, and trac off lights come on again. Took it to a mechanic who ran the computer on it, and found that both the front wheel speed sensors were sending infrequently or not at all. Also, the codes 1232 and 1233 turned up. He thought I needed to change the trac off switch. I think thats crap. He also wants me to do a pricey test, measuring the resistance across the sensor. Does anyone have advice, know how I can do this, know of a cheap ohm-meter (or something similar) I can use? Also both hubs have a life-time warranty, so I could always just trade them in for new ones...
Also- another thought. My car had been rattling intermittently. Only when the a/c was off, would it rattle, and only occasionally, even then. It has become more persistent over time. The tech looking at my car noticed that the pulley on the a/c compressor is rubbing against what he called the "clutch palte" of the compressor. Usually there is an 1/8 inch or so space between the two. Can I fix this, or is this a signal that the compressor wants to end its life?
Thanks again.
joe
Old 10-19-2005, 02:46 PM
BNaylor's Avatar
Re: DTC's
Thanks again.
joe
On wheel sensor resistance all GM "N" bodies - Grand Am, Alero, Malibu, it can be measured with a digital multimeter in the ohms position. You can get cheapy but effective meters at Radio Shack.
It will read a range of 1530 - 1870 ohms.
Sounds like you may have to take advantage of the lifetime warranty on the hub/bearing assembly. Good luck!
Timeslip 08/12/06
