Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 09-02-2005, 06:21 PM
ml_stx03 ml_stx03 is offline
Question 91 Camry V6 - Knock sensor
The check engine light on with code 52 - Open or short in knock sensor signal.
How many knock sensor does this car have? I found one between the V-engine heads behide the front.
Any advice on troubleshoot procedure for this problem is greatly appreciated.
Old 09-02-2005, 06:24 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 91 Camry V6 - Knock sensor
It has two knock sensors, one on each bank. Knock sensors don't usually go bad. Most of the time is a bad connection or damaged wiring.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 09-04-2005, 07:53 PM
Toysrme's Avatar
Toysrme Toysrme is offline
AF - Advisor
Send a message via ICQ to Toysrme Send a message via AIM to Toysrme Send a message via Yahoo to Toysrme
Cool
Exactly what he said.
Toysrme257th - AIM about anything, anytime; including v6 turbos.
World's second ES 300/3vz-fe Turbo.
