Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 05-07-2002, 01:33 PM
lfein lfein is offline
Question '97 328i Secondary Air Pump Noise
posted 05-07-2002 11:01 AM
I isolated the noise to this secondary Air Pump (11 72 1 744 490). The noise is like an electric motor having trouble. It only makes the noise during warm-up. It has some clips on the side like it can be opened. While it makes the noise the engine seems to run OK. Before I buy a new one at $180, or open it try to open it, does anyone know if it can be repaired, or maybe there is something lodged in it somewhere.
Old 07-19-2002, 03:17 PM
mark canales mark canales is offline
i had this problem with my 328i 97 also it only ocurred when cold (when the pump is needed) what happened is that the one way valve inside it became a two way valve and sucked in water thus damaging the the pump. fortunately it happened to mine while under warranty
Old 11-22-2002, 10:46 AM
gavelez gavelez is offline
Send a message via AIM to gavelez
I have a 96 328i also, and I was told that the air pump noise is normal. It is basically a vacumm for the fuel line or something. the noise is normal to come up on startup.
Old 05-30-2003, 08:42 PM
paulauma paulauma is offline
Lightbulb
Actually, It's an emissions reduction piece. It blows (supposed to blow) air into the exhaust to reduce hydrocarbons at startup. Mine also filled with water so I guess the valce inside mine is shot too?
secondary air pump systems mertzy7 Problem Diagnosis 3 10-12-2007 05:11 PM
Does secondary air pump need replaced? McKaitkal35 Venture 5 06-19-2007 09:17 PM
Secondary Air Pump snalion Intrigue 1 08-11-2006 09:05 AM
Secondary Air Pump Won't Stop Running GeneP Sonoma | S-15 0 03-01-2006 06:05 PM
Secondary Air Pump Replacement Lazanis Blazer 1 07-11-2004 06:46 PM
