Old 08-28-2005, 11:23 AM
eillob's Avatar
eillob eillob is offline
Girdle trouble
Im adding a girdle to support the main caps in my motor. With this blower on here I wanna be sure I don't split the block. The one I ordered online has presented a problem. The problem is with it in place the oil pick up tube will not clear the girdle. If anyone has ever seen a DSS main support bracket you know what Im talking about. The side of the girdle that the tube is on is notched. This one I have isn't and neither is any of the other girdles I have found on line, except the one from DSS. So my question here is why the hell would anyone make a girdle without this modification.
Surely im not the first person to run into this problem. Is there a different pick up tube available that I need to buy? Or do I need to return this one and just buy one from DSS?
Ported Cobra Intake, Ported & polished Windsor Jr heads, K&N, Vortech s-trim, 90mm Lightining mass air meter, 70mm throttlebody,1.7 roller rockers, BBK Long tube headers, offroad H-pipe, Crane cam, main cap girdle, 40 series flowmaster, 3.73 gears, MSD ignition, CGS subframes, A9L PIH kit, SCT custom burned chip, 42lb injectors, 190lph fuel pump, T rex and fuel pressure regulator, AFCO racing radiator
(If it doesn't scare the Hell out of you it isn't fast enough)
Old 08-28-2005, 12:28 PM
351wStang's Avatar
351wStang 351wStang is offline
Re: Girdle trouble
To be honest with you a girdle wont save your block. The best it will do is hold everything somewhat together for you in hopes of not damaging your rotating assembley. Atleast this was all I heard when I was considering putting a girdle on my stock block.
1969 Cougar
357w & TKO - 475hp
Old 08-28-2005, 12:33 PM
SkylineUSA's Avatar
SkylineUSA SkylineUSA is offline
Send a message via AIM to SkylineUSA
Re: Girdle trouble
/i would just grind it.
R32 GTR w/351w .020 forged, 8.9:1, PTK T76, Turbosmart 40 BC & 45 WG, Tial 40 BV, AFR 205s 310/245, 228/228 550/550 114 Hydro, 1.7rr, Isky RLs, 4" HKS exhaust, ARC 30x16x4 IC, 8 point cage, C2 gauges, 2 step, C4 3200 stall w/ R Manual & Hurst Ratchet shifter, 17" Panasport G7s, CSU 750 & bonnet, Vic Jr intake, 3.63 gears, Corbeau Carrera seats, Custom wide body, Bomex side skirts and rear 1/4 caps, Tommy Kaira bumper.
Old 08-28-2005, 03:46 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
#1. Girdles don't add strength cause the weakest part of a 302 is the main webbing in the block center and a girdle isn't gonna fix that. All a girdle will do is prevent you from spilling cranks and rods onto the street saving them. But if you internals are stock why bother you can buy stockers again cheaply.
#2. Things like this are a common problem wit main girdles. When I use one I use Canton's cause I can get their girdle, pick-up, and pan and know that everything will work and I don't need to clearance a Canton pick-up and pan for a D.S.S./Trickflow etc.., girdle.
#3. Bend the pick-up, grind the girdle, get a different pick-up can all be possible solutions. Your gonna have to figure it out honestly cause there is no standard design when it comes to girdles and this is a very common problem. Do what you have to, to get it so the pick-up sits right in the pan.
#4. Just so you know your block should be lined bored with the girdle your using. Many people don't but it is how it's suppose to be done.
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 08-28-2005, 04:05 PM
silverstangs's Avatar
silverstangs silverstangs is offline
Send a message via AIM to silverstangs
Re: Girdle trouble
I couldn't have said that better..........
My ride at my site Silverstangs.
Old 08-28-2005, 04:17 PM
eillob's Avatar
Well correct me if Im wrong but I thought cap walk is what caused the cracking in the main webbing. It was explained to me that if the girdle was used you can effectively stop cap walk.
http://www.dssracing.com/mainsupportsystem.html
Old 08-28-2005, 10:25 PM
GTStang's Avatar
Stang Guy
Re: Girdle trouble
All main caps are anchored to the main webbing, the girdle is just tieing all the main caps together which means the girdle is still anchored to the weak main webbing, so your still only as strong as the weakest spot of the main webbing of the block still. So you have not increased the strength of the main webbing at all.
But you say what about the fact that by tieing them all of the main caps together you spread out the force over the entire main webbing.... Well it doesn't work like that, if your putting enough abuse on the weakest main cap to start to get it to walk this is the best you could hope for(it doesn't even work this well in actuality). It will spread the forces created from the cap that starts walking to the rest of the main caps evenly. But now that added extra force is going to find and take and start to take out the next weakest main cap. Now you have the force of two main caps trying to walk instead of one. So now you have more force spread out over less main caps, basic snowballing effect. Sure you could say there is the magical extra amount between the weakest and second weakest. But that could be nothing and at best a small gain of total abuse the block can take.
I like D.S.S. products and don't have a problem with them but they are just like any other company, they advertise to sell.
They advertise that there level 20 CNC block(stock block) can withstand x amount of hp which is way more than what is commonly accepted for a stock Ford 5.0 block. The bottom line is the 302 main webbing is thin and it breaks and no amount of CNC-ing is going to improve that. But they advertise it...
