Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-26-2005, 05:01 PM
importartist importartist is offline
dead car
I am posting this in general, because i don't know where else to post it. Anyways, I went to start my car today and nothing happened. No dash lights came on or anything. I am thinking it's a dead battery, but i didn't leave my lights on. If anybody has any idea or help it would be appreciated. I hope it is a cheap fix.
1996 Eclipse GS
5 spd. - stick shift = more fun
AEM V2 intake
Chrome headers
Magnaflow tail pipe
Tails
Old 08-26-2005, 05:04 PM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Re: dead car
Sounds like your battery died
P.S.- Any fix it questions just put them in problem diag. at the top.
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 08-26-2005, 11:32 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: Re: dead car
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 08-27-2005, 01:10 AM
Skugulgurk's Avatar
Skugulgurk Skugulgurk is offline
I had a similar problem with another car of mine. if the car won't start with a jump, try and arc the starter with a screwdriver. If nothing happens the solonoid is bad (of course check the battery first and make sure it has a charge.) On my car it turned out the solonoid just called it quits over night. And the way that it got messed up also drained the battery over night. Hope you trace it down.
99' eclipse GS 420A !!!TURBO!!! Hahn kit installed. still on stock everything else, including exhaust.
I know it's taking FOREVER to finish the write up but the bands been taking off lately killing my free time. I've got some pictures posted though if you want to check it out.
www.angelfire.com/indie/kbracing
Old 08-27-2005, 03:38 PM
tr10av tr10av is offline
Send a message via MSN to tr10av
Re: dead car
And if it won't start when you put the screwdriver to the starter, hit the starter with a hammer really hard. The reasoning behind this is some of the wires get stuck together or you have a bad spot on your starter, and you need to break them apart. It's kind of tight to get in there, but I was able to. Once your car is started get it to your mechanic because you can only hit it a couple of times before that won't work anymore.
