Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 08-26-2005, 01:19 PM
Chevy_Boy Chevy_Boy is offline
Ignition Switch
Finally I had my jimmy looked at and found out there was nothing wrong with the transmission and the reason why it seemed it was slipping in OD and D was because of a bad ignition switch... Now i am just curious on how much this will cost to fix. The transmission shop wouldnt tell me and wouldnt fix.... any info would be awsome
Old 08-28-2005, 08:59 PM
drdd's Avatar
drdd drdd is offline
Re: Ignition Switch
I'm guessing your truck is a 1997?
are you getting the Service Engine light?
There are posts on this forum on how to change the ignition switch. A Dealership will probably cost you $200.
Old 08-29-2005, 04:40 PM
Re: Re: Ignition Switch
Yeah the service engine light is on
Old 01-06-2006, 11:35 AM
JDJ JDJ is offline
Re: Ignition Switch
I have the very same problem with the very same year model! Did you have trouble figuring out how to take the key out of the ignition? What did you do to fix it?
Old 01-06-2006, 12:07 PM
blazee's Avatar
blazee blazee is offline
Problem?
Re: Ignition Switch
http://www.automotiveforums.com/vbul...d.php?t=426934
Old 01-06-2006, 12:17 PM
DetroitMuscle's Avatar
DetroitMuscle DetroitMuscle is offline
Send a message via AIM to DetroitMuscle Send a message via Yahoo to DetroitMuscle
Re: Ignition Switch
Ignition switches are easy to change. just drop the column.
Ignition cylinders arent as easy but are doable at home as well.
