Go Back   Automotive Forums Car Chat > Cars in General > Legal Issues > Lemon Law
Lemon Law Share your experiences and receive advice regarding this unfortunate side of the automotive industry.
Old 08-26-2005, 11:54 AM
angelfire angelfire is offline
Lemon Infinity M45 - mold is making me sick
I have a 2004 Infiniti M45 with awful smelling mold in the ventilation system. All Infiniti will do is squirt disinfectants into the system which does not cure the problem. Read about it at www.BadNissanInfinitiCars.com
Old 08-30-2005, 12:41 AM
BullShifter's Avatar
Re: Lemon Infinity M45 - mold is making me sick
There is only ONE THING that will get rid of mold since it is a living organism. The proper way would be to have the interior cleaned and an ozone treatment. I'm sure you can find load of information about ozone treatment at www.google.com
Old 10-11-2005, 08:22 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
'04? It's probably still under warranty. Try another dealer, or write directly to the company.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 10-11-2005, 05:28 PM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
moisture buildup is a nautral byproduct of any A/C system, even your home A/C, some worse then others granted, but it is still normal. letting the moisture sit on the evaporator after shutoff causes microbial growth(mold). i just yesterday printed out a copy of a TSB about the same problem for saturns. their corrective procedure: remove any debris from the evaporator case, clean evaporator with disinfectant or cooling coil coating, and install delayed blower motor control module. cleaning the evaporator with disinfectant is very simular if not the same as infinity's verison, the common do-it-yourself verison is spraying Lysol in the vents. the delayed blower motor control module runs the blower motor after shutdown to reduce moisture buildup. maybe infinity doesn't have a delayed blower motor control module like saturn, maybe you could retrofit one to work. or the easy work around is to turn off the A/C but keep the fan on for the last few minutes of your drive before you shutdown the engine.
Daily driver: 1995 Buick Regal Custom 3.8L 4T60-E 150K miles
Gone: 1994 Saturn SL2 1.9L MP3 168,666 miles
EPA 608 Universal Certification
EPA 609 Certification
Old 10-13-2005, 11:06 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Re: Lemon Infinity M45 - mold is making me sick
The product I use is "Ozium" available at most national auto parts stores. It works. It's sprayed directly into the HVAC intake cowling. If you have a cabin air filter, you can remove it first. The procedure can be repeated annually.
Another suggestion is to not run the AC in the MAX position too much where inside compartment air is recirculated, of course that depends on how your digital climate control is set. Air drawn from the outside will help minimize the bacteria, mold and musty smell.
Timeslip 08/12/06
AF Community Guidelines
