Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-24-2005, 02:33 AM
4G63t Power 4G63t Power is offline
I am desperate for help!!!!
Hey guys, the story goes like this. I borrowed my brother's rx-7 550 cc injectors while he's at the beach, and attempted to install them. To make a long story short, I couldn't figure out how to get them to seat right in the injection holes, so i decided to put the stock one's back in. Well, awesome me dropped the one injector and broke off that cap that surrounds the needle on the injector? I didn't think i needed it... well let me rephrase that... i didn't think it would make a big difference if I installed it anyway. To make a long story short again, the car will start up and then die in 2 seconds. I can keep it running by giving it gas, but runs like absolute shit... tries to die in between gears, backfires, etc. So i guess my question is... what the hell does that cap do? and how important is it that it stays on the injector? I just want to make sure that that busted cap is my problem and that it's not something else. PLEASE HELP!
AWD sold
New car*
90' Eclipse Gs-T
Shaved head with rebuilt motor
Slowboy racing limited slip
compression 165 across the board (:
Fully ported Big 16g with 34mm flapper
Precision racing Fmic
Slowboy Boost controler set at 15lbs
Custom 3 inch turboback
Fully ported o2 housing
Ported 2g manifold
Slowboy racing UICP
3 inch hard intake pipe
SAFC
Autometer carbon fiber gauges
Putting down a solid 300whp
1/4=13.7 at 109
That mph is good for high 12's with traction (:
Old 08-24-2005, 08:51 AM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Re: I am desperate for help!!!!
Cap...on an injector? Are you talking about the connector?
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 08-24-2005, 10:08 AM
ez1286's Avatar
ez1286 ez1286 is offline
Send a message via AIM to ez1286
Thats probably it the injector is letting too much fuel in (ie backfire) you probably need a new injector (just upgrade while your at it)
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff.
http://www.ratemydsm.com/member/ez1286/?member=ez1286
Old 08-24-2005, 10:24 AM
The "cap" i am talking about surrounds the needle in the injector. It's basically like a plastic coating around the end of the injector.
AWD sold
New car*
90' Eclipse Gs-T
Ported 2g manifold
Slowboy racing UICP
SAFC
1/4=13.7 at 109
Old 08-24-2005, 10:27 AM
-Josh-'s Avatar
You're probably flooding that cylinder then, just replace the injector.
AF User Guidelines
Old 08-24-2005, 04:51 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
yup time to replace them. look on the bright side at least you didnt break your brothers injectors too. if your short on money im sure you can find a cheap set of 450's on trader
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 08-25-2005, 09:34 PM
ez1286's Avatar
Is it at or mt i have injectors off my talon i'll send em to you just give me a couple bucks for shipping.
Old 08-25-2005, 09:59 PM
TsiTalon9587 TsiTalon9587 is offline
Send a message via AIM to TsiTalon9587
It's not the insulator that is actually rubber but feels like plastic because it's old and hard, right? If it is, you will have one nice sizes boost leak, thus creating the rich condition.
Aaron B.
95 TSi DSMlink'ed Evo3'ed 6 bolt
52.7 1/4 second try
11.0 1/16th 2nd in league.
22.3 1/8th Ties league record.
6.6 55 meters
Old 08-26-2005, 12:45 AM
Geez... you guys are awesome... Thanks to ez who offered to send me the injectors, but I ordered a set of 550's from slowboy since I've been planning to upgrade anyway.... And nope, those rubber things are definitely still rubber.
AWD sold
New car*
90' Eclipse Gs-T
Ported 2g manifold
Slowboy racing UICP
SAFC
1/4=13.7 at 109
Old 08-29-2005, 02:45 PM
Benag Benag is offline
Don't forget that you have to replace the rubber insulators that come off the manifold too. You're not supposed to use them again.
'95 Eclipse GS-T
5-Speed
Boost, air/fuel gauge.
Old 08-29-2005, 07:58 PM
96spyderman's Avatar
96spyderman 96spyderman is offline
Send a message via AIM to 96spyderman Send a message via MSN to 96spyderman
Hey 4G63t power.... just in case... I didn't see it in your signiature and didn't see anyone post about it... with your bigger injectors you will need an AFC...
I'm sure you already know this but just in case....
"A man's greatest work is to break his enemies, to drive them before him, to take from them all the things that have been theirs." -Ghengis Khan
Old 09-03-2005, 03:44 PM
tsipsi20 tsipsi20 is offline
Send a message via AIM to tsipsi20
Sorry I haven't checked back at my post in a while. But yea, I know you're SUPPOSED to have an AFC, but I had a 2g mas sittin around. I have it all rewired and in there pretty decent. I'm running 18 pounds, and breaking up just a very little in second, but all the other gears are fine. Not to mention, it's hauling ass! I know an AFC would make it perfect, but I still beat an SRT4 by like 3 or 4 cars last night, so it's good enough for me. It is running rich in low rpms though, but i can deal with it. Thanks for the suggestions anyway.
Oh and 4g63power is my brother's name which I accidently posted under.
1990 Eagle Talon TSI AWD
MOD LIST:
______________________
Mitsubishi s16g, Turboback 2 1/2 in. w/ Hi-Flow Cat, ACT 2600 Clutch, K&N Filter, Taylor 10.5 mm Spark Plug Wires, BPR7ES Plugs, Dejon Tool UICP, Turbo XS Type H BOV, Samborskey Shift Kit, Walbro 255lph, Injector Clinic 550's, 2g mas, Vaccum line elimination, SAFC II, Pocketlogger, 17" Motegi Gloss Black Rims, VIS Carbon Fiber Hood, Eibach Lowering Springs, KYB AGX, Homemade boost controller, Autometer Boost/Air Fuel
Old 09-06-2005, 08:17 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
You are going to be running pig rich, about 18% over the stock fuel curve. It will probably max out your FT's and you will end up with a CEL. You are already running rich by not having an AFPR with that 255 FP and not having an SAFC is going to make it even worse.
Just "suck it up" and pick up a logger/SAFC or DSMLink.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 09-07-2005, 01:23 PM
It's been about a week now, no CEL's, and I already talked to a few guys at slowboy about an FPR and all of them said you don't need it, along with all the DSM guys around here that aren't using one and have the 255 lph. I'm not saying that you're wrong, I just think it's not essential. And yes, I know i'm running rich, but a lot of people I've talked to say with a small 16, 550's and a 2g mas, you're running nearly 50/50. The slight break up in 2nd has seized, so I'm assuming the ECU adjusted the timing or something. In any case, that's the status I'm at now, and thanks for the help.
MOD LIST:
Old 09-07-2005, 11:06 PM
I have been running for over a year now on a 255 without an FPR, running rich, yes, but still running without hitches.
Aaron B.
52.7 1/4 second try
6.6 55 meters
