Old 08-23-2005, 08:44 AM
HeWhoKillz HeWhoKillz is offline
exhuast
or atleast I think its the exhuast, it makes a rattle. sounds like metal is scaping against each other or something. i let the car run while i look for the sound and it sounded close to the tail pipe and muffler. does anyone know what it is and how to fix it?
Old 08-23-2005, 11:45 AM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: exhuast
Sounds like the muffler has a loose baffle. Happens all the time. No need to fix it unless it bothers you.
Dragging people kicking and screaming into the enlightenment.
Old 08-23-2005, 04:36 PM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
Re: exhuast
I second that. If it's coming from closer to the cat, it could also possibly be a chunk broken loose inside of your cat. But like curtis said, it's most likely a loose baffle.
Old 08-23-2005, 08:56 PM
wizdum wizdum is offline
Check the baffles!
the only thing to fear is running out of beer
Old 08-23-2005, 10:36 PM
Re: exhuast
im not to bright when it comes to exhunast, define baffles, im gonna need some major explaining on this.
Old 08-23-2005, 11:05 PM
AlmostStock's Avatar
AlmostStock AlmostStock is offline
Re: exhuast
Crawl underneath your car and pound on the muffler and catalytic converter with your hand. If it rattles when you hit it, you found your problem.
Mark's Garage est. 1983
