Old 05-05-2002, 03:01 AM
travis_118 travis_118 is offline
Send a message via AIM to travis_118
need some help with ZC problem.
well I finally got it in and all hooked up (think so) and everyhting. So i try to start it and it wont turn over. it just cranks and cranks. I do believe its the injectors not letting the fuel in. I have checked the fuel rail and it is getting fuel, but the spark plugs are bone dry...... i have checked over the ECU wiring and everything SEEMS to be good. the only thing that i think may be throwing it off is the B10 wire, (thats the one tht has no pin so you have to make one or something...) i ended just shoving a wire in there..is that good? please someone help me. thanks
1997 Toyota 4Runner Limited
Built ZC in 90 Civic std model....
as marked001 says Don't click here
Old 05-05-2002, 08:53 AM
91zc 91zc is offline
Shoving the wire in there is not going to make a good connection. You need to solder on a pin so that it makes a good connection. See if you can scrounge one off a parts car or something you have laying around.
91 civic 4dr
b16a
14.8@94
Old 05-05-2002, 02:06 PM
i dont have any parts laying around to use, and i read that you can use the pin out of B2 or B11.... how do you get the pins out?
Old 05-06-2002, 08:45 PM
Phatman Phatman is offline
Send a message via AIM to Phatman
Yeah, a bad connection may very well be the problem. I believe you can just pull out the pins with needle nose pliers, or maybe push them out from the other side with a small screwdriver..HTH
Mike
Old 05-06-2002, 09:42 PM
okay so i took the pin out of the B2 spot put it is attached to a wire.....do i just cut it?
Old 05-06-2002, 11:26 PM
Looking at this wiring page: http://www.hasport.com/dx_zc.htm .... It says B2 is unused, and to remove, so I would assume that its safe to just cut the wire and go ahead and use the pin ... GL
Mike
Old 05-07-2002, 12:15 AM
Okay i got to tell you and everyone....the write ups on converting DX to ZC FUCKING SUCK!!!!!!!!!!!!!!! everyone i read has something different. they ALL leave out important questions.....like how to take the pins out and what wires you can cut... any ways....if i get time and if i get my car running I will write a GOOD write up on the conversion.
Old 05-07-2002, 01:04 AM
optimuspeterson optimuspeterson is offline
Send a message via AIM to optimuspeterson
i can agree with travis that the instuctions suck. we were both reading it and checking each other and we still didn't understand. i think the instructions would have been better used for toilet paper.
http://home.bendcable.com/optimuspeterson/ <<<<HRC Stage 2 and Star Instructions
95 GS
Mods: Probably a whole lot more than you.
I need some help with my 95' 3000gt.... RedHeadedDemon 3000GT/Stealth 2 06-04-2010 05:28 PM
Need some help with a ZC problem! 91REXSI Engineering/ Technical 3 04-11-2002 05:26 PM
Need some help with a ZC problem! 91REXSI Engineering/ Technical 2 03-30-2002 12:53 PM
